Start Car with Rear Defrost On
Discussion in 'Gen 3 Prius Main Forum' started by WastedTheLight, Nov 2, 2016.
  1. WastedTheLight
    WastedTheLight Junior Member
    16
    Bloomfield Hills, Mi
    If I turn on the heat and defroster then turn my car off, when I turn it back on only the heat is on. Is there anyway around this so when I use my car starter it will defrost without me going out?
  2. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    nope, the rear defrost gets reset to "off" once the ignition is turned off /
    BION
    StarCaller
  3. WastedTheLight
    16
    Not even carista can override this? If not llaaammmeee. It really wasn't made for us winter state people in mind, haha
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    It's configured to shut off when the car is powered down. There is a reason for that. The battery would drain in a matter of a few minutes due to the ICE not running and charging the battery. The electric window defogger draws a lot of amperage.
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Actually, no. No battery drain will occur when the car is turned off. Oh, and the rear window defogger draws a lot of -current-. There is no such thing as "amperage". ;)
    The rear defroster on the Prius, like on just about any car, is run through a "latching relay" system. You can turn it on when the car is on, but it will turn off automatically after some period of time, and when the car is turned off. This is done for a very good reason. If you left it on, as people are wont to do, it could cause problems in the long term. The reason is it can get quite hot, and over time will deteriorate. There have even been cases where the connections to the heating element have loosened and caused a fire, though I'm not aware of this happening in the Prius.
    So while you may think it's "lame", it's normal and done for a good reason. Those of us in the north just have to remember to push a button if/when we want to defrost. :)
  6. BZzap!
    1,607
    877
    How about electrical current?
  7. ReDave
    ReDave Junior Member
    79
    23
    Central California, Sierra/Sequoia Foothills
    2019 Prius Prime
    hey, just sayin'
    am·per·age
    ˈamp(ə)rij/
    noun
    1. the strength of an electric current in amperes.
  8. Former Member 68813
    3,524
    981
    US
    you can easily override it by a remotely controlled finger pushing the button. I'm surprised you didn't think of that, LOL.
  9. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    Check with a remote start install shop. They can help you.
