Start up/No Start up?
Discussion in 'Gen 3 Prius Audio and Electronics' started by VESPAGUY, Jan 27, 2025.
  1. VESPAGUY
    VESPAGUY Junior Member
    37
    KCMO
    Anyone experienced the Start-up button not commencing the Start-up process? Depressing Start - beeps, lights, hums... normal Prius stuff, but the "READY" dummy light doesn't turn on. We've got a 2014 with what I believe to be the original OEM 12V and we're at 112K miles. It does have an aftermarket Rear-view Mirror with Back up Camera which I believe requires a splice into the Brake-light positive current line. Would this affect the Start-up process? Dealer tests the 12v which yielded a 'yellow zone' warning, but it's certainly not dead. ???
  2. ChapmanF
    17,176
    Did the LED in the button turn green when you pressed the brake pedal prior to pushing the button?
  3. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    I'm not a fan of red, yellow, green - Dummy lamps. I prefer solid, precise data points.
    The first thing that Toyota tell you to check is 12V battery condition. Sorry a yellow lamp does not tell us anything because we don't know what the parameters of that yellow lamp means. Was that just a voltage test or a combination voltage and amperage out put test?
    You need to get the battery back onto the GREEN and try again - meaning recharge the battery. If this is a battery issue, you can hook the car to a jump pack to start the car. Then take it down to any chain auto parts store for a free battery diagnostic. Ask them questions. In my experience, they tend to be more forthcoming than dealership personnel, if they're honest. You may have a real problem or just a phantom problem created by a low battery situation.
    Hope this helps...
    #3 BiomedO1, Jan 27, 2025
  4. Mendel Leisk
    40,456
    Dealerships typically use one of the electronic load tester, with a built-in printer. It’ll test CCA, and give that measure, voltage and often a verdict. There are lots of them. I’m using a DIY level Solar BA5 (current equivalent BA9). Ancel has several I think, Topdon, Foxwell and so on.
  5. Brian1954
    Brian1954 Senior Member
    1,698
    663
    South Central PA, USA
    If the 12v battery is 10 years old, it is time to replace it.
  6. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    There’s a sensor behind the brake pedal when depressed with the brake pedal, the on off ignition button turns green to turn engine over when the button is pressed. If the sensor is not fully engaged by the brake pedal, it lots up orange and when you press the ready button, ice doesn’t turn over. Physically adjust the sensor back in place, start stop will be green again when brake pedal is pressed.
    MAX2 likes this.
  7. Mendel Leisk
    40,456
    If adjustment doesn’t help, then I’d suspect the sensor’s failed, or it’s wiring’s been compromised, and so on.
