Starter Battery dead after jump and charge
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jean Kinney, Feb 25, 2025.
  1. Jean Kinney
    Jean Kinney Junior Member
    Washington DC
    2013 Prius Plug-in
    AAA jumped my 2013 plug-in hybrid Sunday (I had left dome light on). I couldn’t leave then, so I left it running for two hours during a meeting, as instructed by AAA, then drove to store, parked, drove home with no problem.
    Today I had to use mechanical key to open door, but couldn’t start the car even with fob on power button. I confirmed I had not left any lights etc on. Dome light very dim when I tried it, so there’s some battery left but not much. This battery is about 3 years old.
    Now what?
  2. Brian1954
    Brian1954 Senior Member
    1,566
    607
    South Central PA, USA
    Two hours of charging of the battery is not enough time.
    The first thing I would do is use a meter to measure the voltage of the 12v aux battery.
    The second thing i would do is connect a 5 amp or less smart charger and charge the 12v battery for a minimum of 8 to 12 hours.
    bisco and MAX2 like this.
    50,811
    Needs a charger, or about 8 hours of run time.
    But even a 3 year old battery can fail if fully discharged.
    If that’s the case, there might be some warranty
