Starter one relay?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rebel7284, Nov 29, 2018.
  1. Rebel7284
    Rebel7284 New Member
    Maine
    Hey folks.
    First time poster here.
    My 2008 prius had, what I thought was a bad battery and only started on the second or third attempt (the message appeared something with p-break problem, please park on a flat surface and press and release break) . After getting a new battery, the issue came back 3 days later. My mechanic says that he thinks it's the "starter one relay" and wants to charge me $700 for replacing the relay (and also the missing fuse box cover). That seems a little expensive for one relay. What are your folks thoughts?
    Note, after the car finally starts, it drives fine, Albeit with a big red triangle and service engine light.
    Thanks for the advice!
  2. Rebel7284
    Maine
    The Toyota dealership recommended I replace the whole fuse box, and wire harness
  3. Rebel7284
    Maine
    To clarify, official Toyota dealership and my mechanic are on very different pages. Toyota wanted everything replaced and wanted to charge me over 4K mechanic wants just one relay replaced but wants to charge me 700 for one relay
  4. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    It’s telling you to press and release the parking brake? Are you sure it’s not the main brake petal? This is going to sound stupid but when it is doing this can you see the brake lights on? Plus any codes in Techstream? If you don’t have it, you need it.
  5. bisco
    49,704
    welcome!
    call the dealer and ask for the trouble codes, and post them here.
    or if your mechanic has tech stream, ask him for them
  6. Patrick Wong
    18,200
    6,479
    Its not good that you allow the car to be operated without a fuse box cover. That will allow moisture and corrosion to develop. Possibly that is why your dealer recommended replacing the entire box.
    If you can figure out which relay has the problem you should be able to buy a replacement for $100 or less. However the key is to be able to identify the failed component.
    05PreeUs and Skibob like this.
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,226
    2,240
    Taylors, SC
    Relay part # is 90987-02025. It's pretty much standard on nearly all Toyotas made in the last 20 years. $85 list at the dealer and about $20 used delivered on eBay. My older friend and I pick them up regularly at wrecking yards for $10. We have about 10 0f them and keep them as spares in our Toyotas.
    Toyota Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
    #7 Georgina Rudkus, Nov 29, 2018
    05PreeUs, Skibob and SFO like this.
  8. Skibob
    2,912
    1,496
    Northern California
    Is the relay a plug and play type or do you have to get into the fuse box to replace it? Yes that’s the good thing about Toyota’s. They like to use the same parts as much as they can, and they don’t change the part numbers between models.
  9. Georgina Rudkus
    3,226
    2,240
    Taylors, SC
    It's in the fuse box under the hood. Just remove the cover, pull out the fuse and mush in the new one.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,809
    Clearwater, Florida
    How do you know which relay the OP is talking about?
  11. edthefox5
    10,096
    4,809
    Clearwater, Florida
    Which battery was replaced the 12 volt battery or the hybrid battery?
  12. Georgina Rudkus
    3,226
    2,240
    Taylors, SC
    There is a guide inside the fuse-relay box cover, The relay is the big inch square and gray.
  13. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    Since others have provided the p/n for the relay, you can match it to a wrecked car....
    To DIY fix, assuming the information you have received is mostly accurate:
    1) Go to a recycling/junk yard, get a relay and COVER, cost you maybe $10.
    2) Stop by the auto parts store and buy a can of "electrical contact cleaner and protector" of your choosing.
    3) Take a good photo of the fuse box with the cover off, so you can see where the fuses all go (they are color coded) and mark the relays with tape or something.
    4) Remove EVERYTHING in the underhood fuse/relay panel that you can (fuses and relays), DO NOT unbolt anything.
    5) Disconnect the 12V in the "trunk"
    6) Carefully perform a VISUAL inspection of the electrical contacts, post a photo of ANY that show signs of corrosion or discoloration (they should all be the same "color")
    7) Spray the fuse box terminals with the contact cleaner/protector, allow to dry for like 30 minutes
    8) Replace the fuses and relays according to your photo, using the "new" relay you purchased
    9) Reconnect the 12V
    10) Make sure the car starts and there are no warning lamps on
    11) Install "new" fuse panel cover
    Good luck, it's an easy job, but time consuming.
    Georgina Rudkus likes this.
  14. Georgina Rudkus
    3,226
    2,240
    Taylors, SC
    Here is a photo of three 90987-02025 relays: 90987-02025.JPG
    05PreeUs likes this.
  15. edthefox5
    10,096
    4,809
    Clearwater, Florida
    I got the fuse box cover in my hand and there's no relay labeled Starter 1.
    There's two 02025 relays one is called P CON MTR the other is for the headlights.
    The P CON MTR relay is for power to the shift control actuator. if that relay failed you would have no shifter. He's able to drive the car.
    #15 edthefox5, Dec 1, 2018
  16. Georgina Rudkus
    3,226
    2,240
    Taylors, SC
    82662-47041 relay box cover 2008 wo auto level.gif Relay box cover is Part # 82662-47041 of your car does not have "auto level." It lists for $52.09 at the dealer and about $38 on line. It is #3 in the diagram.
  17. bisco
    49,704
    why would you carry 10 spare relays?(n)
    edthefox5 likes this.
  18. edthefox5
    10,096
    4,809
    Clearwater, Florida
  19. Georgina Rudkus
    3,226
    2,240
    Taylors, SC
    Didn't need to. My husband's friend had a wrecking yard. It didn't cost us anything. We had the run of his yard and were allowed to pick up any small parts we wanted. There were, at that time, 5 Prius cars on the lot.
  20. bisco
    49,704
    what causes it to pop?
