Starting and Charging System Question
Discussion in 'Gen 2 Prius Audio and Electronics' started by ScubaX, May 31, 2005.
  1. ScubaX
    ScubaX Member
    484
    Redding, CA
    I have searched around this forum for some info the the starting/charging system but came up blank.
    What is the basic idea behind starting and charging of the accessory battery?
    I want to run a CarPC off of the accessory battery. I was under the impression that the HV battery starts the ICE and yet if the accessory battery is dead you need a jump. So the big question for me is how much voltage is drawn off of the accessory battery during ICE start and just ready mode?
    Would you think I need a better battery such as a gel cell or even a dual battery setup? If I went with a dual battery, would the Prius charging it affect the system?
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    the ICE starts by MG1 spinning it over and then the computer feeds fuel and supplies the feed to the IGN coils to fire it. The acc. battery is there to bring the computers to live, and supply 12 volts to the lights and other 12 volt acc. The 12volt battery is charged by the converter on the bottom of the HV inverter assy under the hood. It's charge rate can vary upto about 90 amps and 13.8 volts at any time independent of the ICE running or not. How many amps does the CarPC require? Also the 12volt battery has very limited amperage capacity when the car isn't in Ready mode. Not the kind of battery you can run a bunch of acc. off and not kill it if the car isn't Ready.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    [font=Comic Sans MS:99c28b000e]You might want to consider an auxilliary LiON battery for your CarPC (like running a laptop) which would be charged off the ACC circuit. You don't want to drain your 12V battery. It doesn't power the car, it powers the car's brains.[/font:99c28b000e]
  4. ScubaX
    ScubaX Member
    484
    Redding, CA
    If I go with a Via MB for the CarPC, the draw would be max of 150w from the PC and a few more for the 7" LCD. If a full ATX MB, then probably staying under 300w. With a full size I would run an inverter that would only switch on with Ready mode. I already have tested a 800w inverter off the accessory battery running a compressor that draws over 200w and the Prius worked fine. The ICE ran for a few minutes and then shut off for a while. After about 10 minutes in fired up and charged for a while and then went off again.
    The idea here is to never run the PC without the Prius being in ready mode so that the acc battery would be charged all the time. I might replace the the stock battery with an Optima gel cell that appears to have the similar dimensions. Or, I could run dual batteries just to provide assurance if something went wrong with the system and it continues to draw when no in ready mode. Also, dual batteries could allow me to run for a while without being in Ready mode. But I don't see a real need for that.
  5. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    The aux battery can deliver quite a bit of amperage, that's why it has a 150A fusable link. However its total capacity is small, it has been said to be 38AH. It could run the 150W configuration for about 3 hours. However, the car is designed to shut off ACC mode after an hour.
  6. ScubaX
    ScubaX Member
    484
    Redding, CA
    I think that going the simple route for now will be the best. I will stay with the stock battery but set up the Opus PSU to be powered on with ready mode. It appears that I could easily run this in ACC mode since the Opus will shut down the PC safely at 10.9v. But to play it safe I will stay in Ready mode. As for the Prius shutting off ACC after one hour, that would not matter as the CarPC will be run directly off the battery via the Opus which will be signaled on via Ready mode. When Ready mode is disabled, the Opus will shut down the PC
    That brings up another question, where or how can I pick up a signal for ready mode?
  7. nevesis
    nevesis New Member
    South Florida
    I was thinking of installing a type of car computer myself. But, I've been draggin butt, mostly waiting for my CoastalETech video interface, so I can have a screen for the thing.. But in the process, I've thought of a few ways to handle things. One of my thoughts was to have a real low-power computer such as the net4521 .
    I had an idea to run it much like a laptop, using the guts of a wireless spotlight that has a built-in battery, and takes a charge when plugged in (or, powered-on via a switched ACC line-in). When the car was off, it would run off it's battery, and when on, charge from the ACC line.
    Still, just ideas - since the above mentioned system would run headless, there's no need for me to wait on Dave's video interface - that idea was more of a wireless hotspot, or StompBox idea.
    So, I'm still mulling over ideas on how to incorperate a car computer, or multiple computers. Even the idea of one that is always on (like above), to act as a mobile hotspot, and collect/distribute GPS coordinates, and another more powerful entertainment-class machine (possibly a hacked up X-box) that would integrate with the screen and audio system.
    Also, I was thinking it may be possible to replicate Mr. Vass's CAN project in such a way that the data collected can be stored, and used for not only statistical purposes, but to display on the main screen what is going on in the car in a much more detail-oriented geek-screen. Not only that, beam the data back to home base. My reasoning for this is that I have a friend who works on building car diagnostic computer tools. So, I'd say he knows a bit about CAN and OBD-II and what not. Maybe he can help come up with a way to make this happen.
    All ideas at this point. Any other ideas which may help put any of this together is much appreciated. I really do like the idea of having a system running and available 24x7 which I could just access via wireless from home while the car sat in the garage. Converting to a plug-in hybrid would make linking something up more feasable, but I wouldn't want to plug-in just for an onboard computer, if I'm not going to do some serious battery charging.
    Okay, enough ranting. I've been interrupted while writing this so many times, it probably dosen't make much sense. But I hope my raw ideas were helpful in thinking of projects to start, and perhaps spawn discussions on how to better these ideas.
  8. DanMan32
    3,799
    26
    Tampa Bay, FL
    Most of the 7.5A Ign feed goes to orange wires. One goes to the orange wire of the stoplight switch.
    Skid control is another, Hybrid ECU is another, HV Batt ecu is yet another, and finally the combination meter. Airbag ECU has a black wire providing IG2, but I am sure you don't want to touch that.
    Much of the system gets powered up at Ig1 (Ig-On mode). Also remember that it only has a 7.5A fuse, as its main function is turn on, and not to provide power.
  9. ScubaX
    ScubaX Member
    484
    Redding, CA
    The Ignition or ON/OFF input current: <5mA for the Opus 150w dc-dc PSU.
    nevesis, have you been to MP3Car.com ?
    They have a world of info on CarPC's. The most popular is to use Via's Mini itx boards
    Check out MP3Car Store
    They sell CarPc's, but what is the fun in that? They also have a single din motorized 7" VGA LCD that would go nicely in the storage below the stereo.
  10. DanMan32
    3,799
    26
    Tampa Bay, FL
    Cool stuff. Now all we need is to convert the touchscreen to a USB interface. My understanding though is that the touchscreen is only output to AVC when accessing NAV functions. I wonder if Nav specific Info functions would output touchscreen info, or if you had to be in MAP mode.
  11. ScubaX
    ScubaX Member
    484
    Redding, CA
    I am not even going that route. If that is an eventual solution, it is a ways down the road with someone like CoatalDave inventing an add on device.
    My plan is to use the din space below the stereo that is used for storage. These are two of the touch screen monitors I am looking at:
    7" Motorized LCD
    7" Non-Motorized LCD
  12. ScubaX
    ScubaX Member
    484
    Redding, CA
    Also, you could use the MFD as just a screen using Coastal Tech's ViewTech device. You would have to have your video out as RCA to match their device. You could then use a mini keyboard with bluetooth to input to the PC.
