Starts then shuts off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusde, Apr 5, 2016.
  1. priusde
    priusde Junior Member
    28
    DE
    Car starts runs rough for a few seconds then shuts off (spark plugs and 2 coils were replaced a few months ago). Coolant reservoir level was way low so I filled to the full line, kept the cap off to cycle. During the time the car starts, the coolant from the reservoir violently "boils" over (out of the reservoir). Huge amount of white smoke from the rear exhaust and a burning smell.
    Used Techstream and got the following codes:
    Engine and ECT: P0117, P0302, P3190, P3191
    Hybrid Control: P0A0F
    Intermittently get misfile codes but this time around they did not return.
    51,140
    how many miles on her?
  3. mrbigh
    3,686
    699
    Long Island, NY
    White smoke usually means that the ICE is burning a combination of gaso and water/ coolant
  4. priusde
    28
    DE
    229k
  5. priusde
    28
    DE
    What would cause this and what should be done to fix.
  6. Mendel Leisk
    40,574
    Blown head gasket?
  7. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Most common cause is a broken head gasket which seals the cylinders from the coolant passageways next to them. The cylinder head needs to be pulled to gain access. Worst case if engine got too hot, head and possibly block may need to be machined to fix warpage.
    The cylinders are now pumping air into the coolant passageways which is then blown out through the coolant tank.
  8. priusde
    28
    DE
    Sounds major, what am I looking at for repairs ballpark. I'm seeing decent mileage engines on ebay for around 700, 800 if a swap is something an independent garage could handle.
  9. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Was the engine ever overheated or run low on coolant? I don't think there's any other excuse for such a failure.
  10. Former Member 68813
    3,524
    983
    US
    how about high miles? there are a few threads of blown HG near or over 200,000 miles.
  11. priusde
    28
    DE
    Was running at the low coolant mark but high temp lamp hadn't come on that I'm aware of. Loud popping and rough running when the car does start but then it shuts off after a few seconds.
