stealth chip
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Smee342, Sep 10, 2012.
  1. Smee342
    Smee342 Junior Member
    32
    i hope this is the right spot for this question.
    so ive seen the stealth chip for gen II but nothing for the Gen III, any ideas if anyone
    is working on that ??
  2. gliderman
    gliderman Active Member
    751
    223
    Forgive me, but what exactly is a stealth chip?
  3. Smee342
    32
    I could be weong on the naming, but i thiught that what it was called lol guess im wrong, but the chip that lets you go ev mode up to 34 mgh. Ive read that you can use it up to 2009, but havent seen anything for 2010 an up.
  4. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    I wouldnt be surprised if it isnt available for the 3rd gen. That's just putting more stress on the battery.
  5. fuzzy1
    10,167
    Could you mean the EV mode switch mod for Gen2, to get the functionality already available in the non-US-market? If so, then our (Gen3) switch is already built in, but we are stuck with a different speed limit.
  6. Smee342
    32
    Correct, ok thanks all. :) sorr for sounding newbish.
  7. fuzzy1
    10,167
    Don't apologize just yet, wait for a few more voices to chime in. Just because I might sound knowledgeable doesn't mean that I have it right. I never had a Gen2, so others that did might give a different, possibly even better answer.
  8. David Barton
    David Barton Junior Member
    29
    Bremerton, Washington
    Im pretty sure the Gen III can EV up to 47 MPH right?
  9. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    In Normal Mode and up to 45. EV Mode will only take you up to 25.
  10. bisco
    49,429
    but doesn't the gen III switch not work until ice warmup cycle completed?
  11. fuzzy1
    10,167
    Once the ICE starts, it needs to run at least some of its warmup cycle. But if you hit the EV switch before the ICE starts, then it can go into EV mode, depending on coolant temperature.
  12. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Speaking of which, do you know what temp coolant has to be in order for EV Mode to allow you to go up to 25 instead of ~15?
  13. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    I believe it has to be fully warmed up; so about 70°C/158°F. To be able to enter EV mode before the warmup starts (which will always limit you to 10 mph), the coolant has to be at least 68°F or so.
