stealth or not stealth
Discussion in 'Gen 2 Prius Main Forum' started by fred, May 12, 2004.
  1. fred
    fred New Member
    235
    nashville
    ive had my 04 since march and feel very confident and know it all etc. however.......... i always thought that stealth occured when the ice turned off . well now im hearing that "true" stealth is when all arrows including the green arrows arre not displayed .is that a more pure stealth. i do want to be most proper in my terminology. wheres john when you need him?
    fred in nashville :oops:
  2. jasond
    jasond New Member
    165
    Boston
    It's not a technical term! People can define it differently if they want. I'd call that "coasting", myself. Stealth, to me, means the car's running silently, which means that the ICE is off.
    Personally, I try to keep the car coasting (if I think I'll need to slow down soon) or running on battery (amber arrows, if I think I'll need to maintain or increase speed). The battery recharges itself pretty efficiently even when I knock it down a few bars, and my mileage is up since I've been doing this (though it's also warm out, which I'm sure is a larger factor)
  3. jamarimutt
    jamarimutt New Member
    985
    For me, coasting is moving forward without your foot on the gas pedal and stealth is moving forward under electric power.
  4. fred
    fred New Member
    235
    nashville
    very delineation.!! makes sense to me. seriously, you put it well and succinctly
    fred in nashville :)
  5. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    The ability to coast was extraordinarily rare with the classic Prius (when the term "stealth" was first coined), so it's frequent emergence on the 2004 is naturally a bit confusing.
    Personally, I rarely use the "Energy Monitor". Not having MPG on that screen originally made it far less useful than the "Consumption" screen. So I don't use it often. "Consumption" has that immediate-bar that is remarkably easy to see with just peripheral vision and I like watching that MPG average slowly climb up. In short, I don't know when I'm coasting anyway.
    As for stealth, that is when the engine is stopped (not just off) and you are powering the wheels exclusively with electricity. So coasting (working the "deadband") is part of stealth, just like regen is.
    Then there's "warp stealth". That's when the engine shuts off but remains spinning, like when you drive down a hill on a highway.
  6. fred
    fred New Member
    235
    nashville
    john, you still dman!. ive got a very weird thing going on. my driving distance has really dropped and im only on the road about 10 minutes at atime for work. my mileage is dropping like a stone but i think its mostly because the engine and "catholic converter" ooos i mean catalytic converter are not quite up to temperature. i did get 58 mpg when i drove on the natchez trace parkway for about 200 miles a month ago.
    thanx as always
    fred, your non green friend in nashville :p
  7. daniel
    14,487
    1,519
    Spokane, WA
    Fred, like you I only drive 10 minutes most times. You and I are being more green, not less green than the others. Our mpg is lower, due to the greater percentage of time spent in Phase I, but overall we are burning less gas and producing less pollution. Most green is making lifestyle choices that require less driving.
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Stealth-No ICE, will be accelerting or moving at constant speed with electric power only.
    Coasting-Foot completely off gas, usually decelerating, but may be accelerating or constant speed if on a downhill. There is some 'drag' caused by MG1 with some mild regeneration.
    Gliding-Essentially coasting but with foot slightly depressing accelerator to prevent regen braking/slowing. I use the term to include speeds above 41mph when the ICE may be spinning. I also use the term when I'm actually quickly switching b/w steath, true 'no arrows' gliding and coasting b/c the net effect is a glide and it's difficult to exactly maintain. I think this is a newer term a few of us are starting to use to describe that "no arrows anywhere" state.
    Warp Stealth/Hyper Stealth-Running on electric power only but with ICE spinning--necessary any time you're going more than 41mph.
    Dead-Banding-ICE powered driving with no arrows to/from the HV battery. Considered by some to be the most fuel efficient state since there is zero loss from conversion to electricity and back to wheels.
    Pulse Driving-The principle of 'feathering' the pedal once you achieved your desired speed of travel (ICE off, consumption shows 99.9mpg) and maintaining speed in stealth or hyper-stealth then pulse use of ICE, when necessary, to maintain speed on hills or when the battery is low or other conditions dictate the need for more power.
    These are my personal definitions, most widely accepted, the 'glide' being the exception. Glad to hear any suggested revisions for these definitions. I think Cybele is accumulating a list and it would be nice to have these spelled out.
  9. fred
    fred New Member
    235
    nashville
    ouch, doc., that was a great (!) explanation now about this bump on my head..... :D
  10. rflagg
    rflagg Member
    947
    Springfield, VA
    I've got a techie question for what exactly "warp-stealth" or "hyper stealth" is - I understand that the ICE is 'spinning' without running, but what exactly does that entail? Does it mean that the pistons are pumping without gasoline injected? I'm not really concerned about if the engine can handle it - I've got faith in it, but I'm just curious to how it works. Anyone who can enlighten me on this topic would be greatly appreciated.
    -m.
  11. daniel
    14,487
    1,519
    Spokane, WA
    The Atkinson-cycle engine has the ability to leave the valves open and spin with virtually no resistance, no spark, no fuel.
  12. Ralphmc
    Ralphmc Mr Hybrid
    37
    Nashville, TN USA
    rflagg,
    now that I have observed my new prius a little more, I noticed that the two modes (stealth and W-Stealth), actually consist of 3 modes. To be more exact, the Electric Motor (MG1) knows three conditions. 1. acceleration. The #1. is referred to as stealth mode, since the only propulsion desired here is electric only. The 2 stage is the one where neither the arrows show up green, or amber and all the electro motor does is keeps it self going. The third mode is the mode where the MG1 is used as slow down, or perhaps the arrows are ohly green to charge the batteries. This last mode, at higher speed (>42 mls/hr) will have still the ICE engaged some what, which I have not 100% confirmed for that I wish the Prius had an RMP meter for the ICE only. The reason why I say that is simple, when you put the car on a decent in "B", you will actually hear the ICE spin up as if you had shifted down. But what happens when the Battery is all "Green", whell now is that stage reached where no more effect is achieved by the ICE to regenrerate, and to cause deceleration (engine breaking), now the ICE spins up in the max RPM range, in efforts to introduce mechanical resistance.
    ----------- hope that helps --------- Ralph
