steep end-of-driveway scraping
Discussion in 'Gen 2 Prius Main Forum' started by stock, Oct 9, 2008.
  1. stock
    stock Junior Member
    Any economical fix to the problem of the Prius scraping at the end of a steep drop off of my driveway? Departing at an angle helps as suggested but does not cure the problem.
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    If you can use them, Home Depot sells rubber gutter "ramps" that go into the street gutters.
    Other than that I know of no way to "raise" the Prius for better ground clearance. It's low for mileage (aerodynamics).
  3. stock
    stock Junior Member
    Thanks DB. Do you have a link to view what it looks like?
  4. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    You might try backing in. I have the same problem, ans backing in seems to help. Go slow too. I would like to see the ramps too, but they'd probably get stolen, unless they were really heavy.
  5. ravenmaniac
    ravenmaniac Senior Executive VP of Nothing
    156
    DC Metro Area
    Would a 2X4 work? My neighbor uses one and it's a cheap, but not aesthetically pleasing, solution.
  6. David Beale
    5,963
    1,981
    Edmonton Alberta
    The ones Home Depot sell are made of recycled rubber. They have a "V" bottom and flat top with some ribbing. They are about a foot wide and 3" deep at the "V" peak. They are one car lane width long. They have holes to bolt them down, and a drain groove at the "V" peak.
    We had to get the guys at Home Depot look them up, as they didn't know they sold them.
    I've also seen a 2X4 with a 2X6 or 2X8 fastened to the top in some gutters. The rubber ones are nicer but I suppose they have problems (snowplows IF the city ever plows your street ;) ). Once bolted down they tend to not walk away. They're heavy too. Which helped to discourage thieves.
  7. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    what part of the car would scrape? is it just the black peice under the air dam? isnt that part softer to yeild anyway?
  8. stock
    stock Junior Member
    Thanks. Anyway you could post part #? ~Cost?
