Steering effort
Discussion in 'Gen 2 Prius Main Forum' started by yibo829, May 1, 2015.
  1. yibo829
    yibo829 Junior Member
    84
    I've noticed that steering effort changes with the road surfaces. When I'm on a non-paved surface, the steering effort is much lighter than on a paved road. The same when the road is wet or on grass, the steering is not heavy.
    On regular streets I find the steering to be a little heavy, requiring too much effort to turn, especially when in parking lots or dry steering. The Chevy Cruze I drove required very little steering effort, it's one of those turn using one finger type.
    Did anyone else notice the changes in steering effort with different road surfaces?
    iPhone ?
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    This is pretty typical for any car. The only reason you don't feel it on Cruize b/c it is so light.
  3. yibo829
    84
    Chevy Cruze weighs more than the Prius actually.
    iPhone ?
  4. JC91006
    16,489
    8,402
    You need to drive another Prius and compare the difference. This is all subjective.
  5. ETC(SS)
    6,572
    The XBOX-360 steering is one of the things that I love to hate about the Prius, and the Prius system is twitchier than it needs to be and it leaves the driver almost completely disconnected from the road.
    However (comma!) this isn't a Prius-only thing, and as JC91006 pointed out above, steering is very subjective.
    Handling isn't one of the things that Priuses are lauded for..... ;)
    Electric vs. Hydraulic Steering: A Comprehensive Comparison Test - Feature - Car and Driver
  6. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Hmm...I hadn't noticed. I find the steering effort to be pretty light on all surfaces. I saw somewhere where someone modified the electric assist (with a variable resistor, I believe) to increase effort and feel. I wouldn't want to put more stress on the steering shaft, myself.
  7. fuzzy1
    10,221
    One of the cars I learned to drive on had old style manual steering. My first car frequently suffered engine stalls, causing its power steering to revert to manual steering. And several farm machines I still operate in summer lack power steering.
    So, no, I've never noticed my Prius 'requiring too much effort to turn'.
    Have you had the steering checked to see if the power assist is still functioning? With the car parked, is it easier to turn the wheel when ignition is 'Ready' than when all power is turned off?
  8. yibo829
    84
    Oh yes. It is definitely easier to turn the steering wheel with the car in ready. I'm sure the car's power steering is still working but just not as light as I want it to be.
    iPhone ?
  9. JC91006
    16,489
    8,402
    You've done the steering shaft recall right?
  10. bisco
    49,608
    what are your tyres pressure at?
  11. yibo829
    84
    Yes. The steering shaft recall has been done.
    And my tire pressure is at 32 front and 30 rear. I purposely set them that way for a more cushy ride.
    iPhone ?
  12. bisco
    49,608
    that may be it. try them at 42/40 for comparison.
  13. cyclopathic
    3,292
    547
    2014 Prius c
    Light steering
