Steering paddle for EV mode only.
Discussion in 'Gen 4 Prius Main Forum' started by JayLn, May 7, 2017.
Tags:
  1. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Just curious why Toyota never install a Steering Paddle just for EV mode so we can go to speed and then release the gas and use the paddle to maintain speed in EV mode, this will maximize the fuel efficiency of the car rather than doing the EV on the gas because sometimes you go over and activate the engine.
    Hope someone can mode our 4th gen Prius to do this. Just saying.
    GlennCocoBad likes this.
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    They already did. It is called the Prius Prime. The Liftback is an HEV - Hybrid Electriv Vehicle, not designed to run much is solely EV mode.
    The Prime is a PHEV, Plugin Hybrid Electric Vehicle, with the larger battery and EV modes designed into it to support more EV driving. The Prime can be recharged by plugging in, greatly reducing the need to run the engine for many people.
  3. Imaginex20
    Imaginex20 Active Member
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    Toyota did. It's called cruise control
    pilotgrrl and FuelMiser like this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    (Your profile shows a 2015 PRIUS - I'm answering assuming that's an error)
    It won't improve fuel efficiency much, if at all - forcing it into EV mode on a hybrid is, in most cases, self defeating. The only time it's really an advantage is if you want to move the car a small distance where it can prevent the ICE from starting up - I have two places I do it - one situation where I turn 80 metres past a traffic light and then it's downhill, the other is 200 metres starting from home cold and out of my slow speed cul-de-sac, after which is a hill when the ICE kicks in - but I haven't found many situations like that.
    If you use up all the battery capacity by playing with EV, it means that the next time your PRIUS comes to a place where it would normally go into EV mode it says "whoops - someone has used up all my hybrid battery, I'll need to use the ICE instead - plus I'll have to keep it on longer to recharge my battery".
    For most of us, and most of our driving, it's best to just drive it in an economical manner, anticipating stops, moderate acceleration etc.
    You can hypermile if you want to improve your fuel use, but that's absolutely different from forcing EV Mode.
    kithmo, RCO and MichelleStone like this.
  5. bisco
    49,446
    does prime have steering paddles?
  6. Prodigyplace
    11,696
    11,318
    Central Virginia
    I don't think so, but is has more aggressive EV modes.
    I believe the Corolla S has paddle shifters for its CEV. Other than handicapped equipped vehicles, I am not sure hand speed controls are used in the US in cars.
    Just to further confuse things, the thread title refers to paddles for steering.
    Are we confused enough yet? :eek:
    EDIT: I found a car with a hand throttle - the Model T.
    #6 Prodigyplace, May 7, 2017
    kithmo likes this.
  7. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Only for when you're afloat, I guess. I think they come with a collapsible bailer and red & green navigation lights in an optional kit.
    #7 RCO, May 8, 2017
    kithmo, bisco and Prodigyplace like this.
  8. Prodigyplace
    11,696
    11,318
    Central Virginia
    Amphicar still lives??
  9. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Never did in my mind. They had one in Maala when I was there in the sixties. Not absolutely certain but think there were water ingress problems.
  10. Prodigyplace
    11,696
    11,318
    Central Virginia
    I actually saw them when I lived in Canada.
    I remember them at a car show in a water tank and at least one parked on the street.
    #10 Prodigyplace, May 8, 2017
  11. alanclarkeau
    7,044
    7,584
    Plus - there have been many unsuccessful tries:
    Sooner Al likes this.
  12. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    I am guessing you are not really familiar in driving a prius, you go to speed you like and release the gas to turn off the engine and use Electric motor to maintain speed, my idea is to have a paddle button to maintain EV because on the gas pedal, you have to maintain the amount of pressure to stay on EV, so if we have a paddle EV button on the steering, we dont need to constantly look at the gauge to maintain on EV. Just to be clear I am not arguing and I am not talking about EV mode Mode which is pretty much useless imho.
    And I am on the right thread I have a 2017 4 Touring love the adaptive cruise control.
  13. Chippingawayatlife
    Chippingawayatlife Active Member
    159
    116
    San jose
    I think the confusion in this thread will be reduced if we reworded "EV" to "neutral". It's the pesky, yet useful "creep and engine brake" feature. For example, speed up to 75 mph on the highway and press a button to disengage the ICE and coast without battery or engine assist. I would love for Toyota to put that switch on the steering wheel. That way I can cruise after speeding up with the ICE on the highway without using a bit of throttle or switching to neutral and hearing that beep.
    RCO likes this.
  14. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    That would be fine too but my idea is a button on the steering to keep gas engine off and let the Electric motor work, because most of the time I can maintain 65mph just using electric but I need to constantly look at the gauge to make sure I dont pass that middle line and activate the freaking gas engine so annoying, but if we have a button just to activate Electric motor I think it would super okay.
  15. Prodigyplace
    11,696
    11,318
    Central Virginia
    Running the Prius Hybrid trying to maximize EV like that will generally hurt your fuel mileage. Some people believe it can also shorten the useful life of the traction battery.
    You want the EV Mode that is in the Prime that has a larger traction battery. From the Prime manual;
  16. kevinwhite
    kevinwhite Active Member
    331
    199
    Los Gatos Ca
    I don't see that it is necessary or will improve system efficiency.
    One of the things I have notice with the Gen4 compared to my previous Gen2 is how aggressive the system is to turning off the ICE.
    Even when cruising at 60mph or so I will often notice the ICE is at zero RPM (I have an Ultragauge).
    If the required power demand is below what the ICE can deliver efficiently (~10kW) and the battery is at a suitable SOC it will automatically run on battery alone.
    I'm sure that if I forced it to EV I would then run the penalty of the 25% energy loss from the ICE to battery and then to MG2 getting an overall lower efficiency.
    kevin
  17. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Okay guess I am enjoying the adaptive cruise control better than this gas fuel efficient crap I want to save, I am getting 54mpg here on sf uphills with the 17 touring rims, I am planning of buying the 15" Prius stock rims, because on my 2015 Prius I am getting 50-70 mikes more per tank just by using the 15" rims compare to the persona 17" rims
  18. Prodigyplace
    11,696
    11,318
    Central Virginia
  19. alanclarkeau
    7,044
    7,584
    Yes, this is the right thread - just that your profile shows you've got a 2015.
    I love the adaptive cruise control (DRCC) too - I couldn't go back to an ordinary car again.
    True, the EV MODE Button is only useful in limited low speed situations - and with the relatively small battery, it would not be very useful at higher speeds.
    I know what you're saying - but letting the Hybrid system sort it out seems to make little difference compared with trying to maximise the time in EV at higher speeds. My experience (on a reasonably empty highway where I wasn't annoying other drivers - which is easy to do with hypermiling) is that at highway speeds, pushing EV use to the limit drops the battery quite quickly, and when it drops, you have no alternative than to let the ICE run to charge it up. It will actually keep running at that point till it gets to at least ½ charge, even on dead flat or downhill situations.
    The hybrid system is programmed not to stress the hybrid battery, and I notice that it will try to re-fill it, so it is ready for places where it can be used to best advantage.
    I concur that hypermiling has an advantage over the Hybrid system's computer in that you can see the road ahead, whereas it doesn't, so there are places where you might be able to eke out a little more distance from your fuel. And, for sure, you can improve mileage by intervening - unfortunately not while using DRCC.
    With 15 vs 17" wheels, I saw a few threads about changing rims (both going bigger and smaller). Check out the threads to see what they said.
    kithmo and Chippingawayatlife like this.
  20. Chippingawayatlife
    159
    116
    San jose
    Seems that the points are hammered home, but I'd just like to reiterate that these senior members here in this thread/forum are very helpful. They are very patient with they're responses. I was in the same situation before, thinking it's better to utilize the traction battery, but these guys led me in the right direction. Then I found plenty of old threads where these same guys offered the same responses for others. Very patient and helpful.
    kithmo, RCO and Since2002 like this.
