Steering rack & pinion
Discussion in 'Gen 2 Prius Technical Discussion' started by AlexY, Jul 25, 2015.
  1. AlexY
    AlexY Member
    160
    45
    UK
    In short - I've fu***d up purchase, bought 2006 Prius which clearly was involved in accident, though it was small collision in slow traffic but on my way home from seller it was clear this was something more serious when on motorway at 70mph steering wheel started vibrating when in straight direction, it disappeared on any little turn left or right. Ok, maybe just ball joint got loose.... but not, today I've lifted front and found little knocking sound in few positions when turning the wheels (L-R). Sound is coming from rack & pinion unit. Anyone removed, disassembled and successfully assembled it? My plan is to check with dealer what is the cost of replacement (quite expensive for gen I, expect it to be same for gen II) alternatively can get one from scrap yard but need to find the calibration procedure first.
    BTW did read codes as follow, it's clear after reset... so far.
    49,436
    has it had the steering shaft recall?
  3. AlexY
    AlexY Member
    160
    45
    UK
    Checked toyota website, it say:
    We are pleased to confirm that your Toyota is not affected by any voluntary customer service campaigns or outstanding safety recalls and no further action is required.
    49,436
    bummer. how many miles on her?
  5. AlexY
    AlexY Member
    160
    45
    UK
    135k but this is not mileage related issue.
  6. bisco
    49,436
    right. i don't recall any threads on steering rack any luck searching google?maybe try toyota technical manual to see if there is an adjustment to take up play?
