Steering smoothness problem
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by amilamad, Oct 30, 2015.
  1. amilamad
    amilamad Junior Member
    Hi
    My prius c ,s steering wheel is sometimes smooth but sometimes its hard. I tested on the same road with only me inside the vehicle. Is there something wrong with the rack ?. Should I check my car ?. My tire size is 195/65/r16
    Thanks you
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Is it random or it happens at specific place?
  3. amilamad
    When its bit hard it will hard for few days. not in a specific place.
  4. cyclopathic
    3,292
    547
    2014 Prius c
    if it is still under warranty go to dealer and have it checked. Sounds like there some issue with rack or at least with loose or corroded contact, so it doesn't get power. In humid climate many electric issues can be traced to contact corrosion.
  5. bisco
    49,492
    is variable speed, yes?
