Steering wheel Bluetooth buttons (adding)
Discussion in 'Gen 3 Prius Audio and Electronics' started by rrolff, Apr 11, 2010.
  1. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Has anybody researched adding the Bluetooth buttons to the steering wheel?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    I added the buttons in my 2006 Prius and they are programmable with SWI-JACK. The latest firmware listed bluetooth phone support for it. Since you got a Pioneer unit, check SWI-PAC firmware to see if it is supported.
    This is the video demonstrating how I programmed it.
  3. WaterbedWarrior
    WaterbedWarrior Going insane!
    65
    23
    33
    Parma, OH
    I've got a package II, so when I replaced my head unit, I used SWI-JACK to set my steering wheel "Mode" button as my bluetooth button. Therefore to pickup a call I just press the mode button. If I need to switch between FM/AM/DVD/USB I just press the button on the head unit. Much easier than trying to add buttons or swap steering wheels.
  4. rrolff
    1,610
    246
    So Cal
    There's a standard set of buttons that get added to the other side. No steering swap.
    I want it for both Bluetooth functionality - and other radio options...
  5. austingreen
    austingreen Senior Member
    13,569
    4,104
    Austin, TX, USA
    If there is an easy way to add on buttons, I would like to try it. I'm fine just hitting the buttons on my head unit right now though.
  6. Rainingblood
    Rainingblood Junior Member
    35
    Italy
    very interesting, i've a european "active" prius (without bluetooth) and i've buy a alpine 114bti HU with bluetooth... maybe changing the steering wheel we can use the bt button! but how much it cost???
  7. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I have a 2010 Prius II. I'll have to ask the dealer about ordering the part on the left of this steering wheel, with the Voice and Answer/Hang Up buttons. (Hope the picture shows up).
  8. rrolff
    1,610
    246
    So Cal
    I worked with the parts guys to try and track this down. They can order the buttons/wiring harness - but they come as an assembly - including the existing volume, the other side temp control etc. The set runs $588 (needless to say, this is one mod I am not doing).
    dgaus and EdyJun like this.
  9. EdyJun
    EdyJun Junior Member
    58
    Los Angeles
    Any ideas if you ever did this mode, and also, can you please explain what is needed exact? (is the harness behind the steering wheel?)
