Steering wheel buttons not working and SRS airbag icon on dash
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aryabasu, Dec 14, 2017.
  1. aryabasu
    aryabasu Junior Member
    28
    Atlanta. GA
    Hello all,
    I have a 2004 Prius and I have the SRS airbag icon on the dash on.
    Some of my steering wheel button controls are defunct. I also have B1801 code on!
    Could anyone confirm, if this is a shorted spiral cable issue? I have replaced it last year.
    Thank you.
    Arya.
  2. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    I think you might be having some problems with the spiral cables.
    Open up the centre air bag stuff, and inspect the cables.
    PS: You've got to be very careful, when working on airbag systems, because it could deploy dangerously at you.
    So, follow all safety precautions when working on it. For instance, on Toyota vehicles, even the hybrid, you got to disconnect the 12volt battery, and allow the capacitor holding the charge for the airbag to discharge for say, 10minutes or so, before opening up the centre of the stuff in the steering.
  3. aryabasu
    28
    Atlanta. GA
    Thank you! Is there a possibility that something else is screwed up? Like other sensors?
    48,946
    probably not, but it might be worth checking for trouble codes.
    Raytheeagle likes this.
  5. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    Some people have found that the cheaper third party cables do not work as well as the OEM one. That could explain a relatively early failure.
  6. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    As regards the buttons not working, check the wirings on that button when you open up the pad at the centre of the steering wheel
  7. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    Y not try taking out the airbag cable from the centre of the steering wheel, and replacing it with a new OEM one, or if you want it cheap, you could get some functional used ones from eBay, or junkyard?
    But the problem might be you might have to be removing and replacing, until you get the right one
  8. aryabasu
    28
    Atlanta. GA
    My horn is not working and all the buttons are degeneratively have stopped working.
    I think it is the spiral cable after all. Is that right??
    Prodigyplace likes this.
  9. Prodigyplace
    11,696
    11,317
    Central Virginia
    Very possible. Check fuses first, though.
