Steering wheel buttons not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lpf, Mar 10, 2020.
  1. lpf
    lpf Member
    113
    33
    Greece
    New to this forum but ready to appreciate any help. After searching posts for similar problems I see that the main reason causing non-working buttons is the clockspring. In my case turning the steering wheel left or right does not alter the result: defoggers and re-circulation switch are not working. Maybe the cable that goes from the switches to the clockspring is broken?
    I've noticed that many ebay sellers offer clocksprings at very low prices, with the note that has no steering sensor. Should I avoid these?
    49,482
    Yes and yes
  3. lpf
    lpf Member
    113
    33
    Greece
    Thanks. If you know, do are there 2 cables, one for the phone/voice section of buttons and one for the defoggers?
    49,482
    No, just one. But not all the connections go bad
  5. lpf
    lpf Member
    113
    33
    Greece
    OK I will check this cable...
  6. bisco
    49,482
    Yeah, or look for a low mile salvage
