Steering wheel clunking noise
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ImeanGreen, Jun 25, 2014.
  1. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Hello people. It's been a while since I got back to this forum. Just want to give you some heads up regarding my steering wheel clunking noise. I have my V for a year now and at 15K, the steering clunking noise started to appear that was intermittent in nature and I could not easily replicate the problem. 4 months ago with 20K miles on it, the clunking noise/steering feel just got worse and could be replicated right away. Brought it to the dealership and they were able to solve the problem. The problem was the intermediate shaft. Replacing it totally eliminated the problem. This seems to be a problem with other car manufacturer's too if you Google " intermediate shaft problem ". Hope this helps you guys who have the same problem. Cheers.
  2. Uberfast
    Uberfast Junior Member
    76
    Oakland , ca
    2014 Prius v wagon
    Was it's under warranty. Did the dealer pay for this. Was it under a recall also. Thank you so much for your response
  3. mikefocke
    3,719
    1,662
    Sanford, NC
    Intermediate shaft is also an internal to an engine part on many makes and I'd wager 98% of the online references are related to that part. The purpose of the intermediate shaft is to drive the camshafts indirectly off the crankshaft. By using an intermediate shaft, the speed of the chains are reduced, which is better for chain life.
  4. qaz111111
    qaz111111 Junior Member
    wrong intermediate shaft. This is the joint in the steering column shaft.
    Air_Boss likes this.
