Steering Wheel Removal
Discussion in 'Gen 4 Prius Technical Discussion' started by mannymendez25, Jun 7, 2023.
  1. mannymendez25
    mannymendez25 Junior Member
    45
    25
    Miami
    2020 Prius
    My wife's 2019 steering wheel fake leather is peeling. I took it to Toyota a few months after the warranty expired and obviously they said sorry, the warranty expired. I found a local guy that can reupholster the steering wheel for $180 but I have to take him the steering wheel. I am very mechanically inclined but would prefer any guidance from anyone that has removed the steering wheel. My main concern is airbag and was wondering if there is a way to disable COMPLETE power to avoid an air bag deployment.
  2. sclevine
    sclevine Active Member
    117
    136
    New York, NY
    2024 Prius
  3. TucsonPrius
    TucsonPrius Member
    167
    Tucson, AZ
    2020 Prius
    If it's like a 2004 Prius, I believe all you need to do is disconnect the 12v battery and let the car sit for 30-60 seconds. I generally waited a bit longer than that, plus the takes some time to get the steering wheel apart, etc.
    Of course the best way to know for sure is to check the repair manual.
    Shawn
    [Edit: And of course, never place the steering wheel on anything with the airbag pointing down.]
    #3 TucsonPrius, Jun 7, 2023
  4. ChapmanF
    15,616
    You generally remove the airbag from the wheel for access to the wheel-to-column nut (which, of course, you do after the right waiting time for power to drop). So that last bit simplifies to, don't set the airbag anywhere with the bag side down and the metal side up. (Likewise, don't set it against a wall with the bag to the wall, etc.)
  5. mannymendez25
    45
    25
    Miami
    2020 Prius
    Any online instructions on how to remove the airbag?
  6. ChapmanF
    15,616
