Steering Wheel "Sluggish" and Not Returning to Center
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Critic, Mar 12, 2011.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,323
    CA
    My friend has a 06 Prius with about 85,000 miles.
    Ever since he purchased the car (used) at about 67,000 miles, I've noticed that the steering wheel is slow to return to center and the steering lacks the "springy feel" of the low-mileage Priuses that I have driven. I noticed abnormal tire wear on the car so I suggested 4 new tires and an alignment-- which was done without any improvement. The front toe was set to 0, and the rear toe is minimal (0.05 and 0.1 on the LR and RR, respectively). However, I did not have a zero-point calibration performed at the time of the alignment.
    There is no obvious damage or wear to the suspension, as far as I know. Recently though, the steering wheel has decided to clock itself to the right so I know it needs another alignment. It has only been 17k since the last one. Are there any parts that I should consider replacing before doing this alignment?
    Thanks.
  2. sktn77a
    sktn77a Member
    294
    NC
    Tires/tire pressures?
  3. The Critic
    3,193
    2,323
    CA
    Pressures are set to 40F/38R. Lower pressures don't make much of a difference either.
  4. Patrick Wong
    18,200
    6,479
    This doesn't sound good. There may be worn parts in the suspension or the steering gear itself.
    Considering that the steering system is vital to safe operation of the vehicle, I recommend that the steering and suspension should be checked out by a local Toyota dealer.
  5. sstk100
    sstk100 Junior Member
    Ne
    Could well be the steering rack.....they do what your describing when going bad.
