Steps to take if only using the Prius once a week for a while?
Discussion in 'Gen 3 Prius Main Forum' started by RubikTetris, May 24, 2023.
Tags:
  1. RubikTetris
    RubikTetris New Member
    Montreal
    I’m sure some of you had that experience of not driving much during the lockdown. I’m currently in a situation where I have a newborn and I’m always home. In fact I’ll probably have to find excuses to drive 30min every week just for the well being of the batteries.
    Should I get a trickle charger for the 12v battery?
  2. Mendel Leisk
    38,665
    Our scenario is similar, 2010, used once or twice a week, and usually a good drive when that happens.
    In between those drives I keep it on a charger, and for convenience have the charger’s quick-connect cable installed.
    I’m using a CTEK 4.3, good charger, but getting a little pricey. Current similar version is CTEK 5 I believe.
    #2 Mendel Leisk, May 24, 2023
  3. Leadfoot J. McCoalroller
    7,140
    6,688
    Pennsylvania
    2018 Prius c
    If yours has the smart key system, you can throw a switch to temporarily disable it for the 6 dark days.
    I don't think it is worth much more trouble than that.
    (quite a few of my own posts written between the moments of toddler care here, welcome to the club!)
  4. Mendel Leisk
    38,665
    2nd gen has such a switch, but not 3rd. Perhaps not needed as much, but yeah the battery will run down with a steady regimen of downtime.
    We’re garage stored, charger connection very convenient, so why not. The current 12 volt (Optima Yellow Top) will have been installed 8 years this September.
    Attached pic is recent, taken the morning after a driving day, before connecting the charger, so no surface charge I would think. I also periodically test it with a Solar BA5: it’s still well above CCA spec.
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,011
    763
    Virginia, USA
    Putting aside the health of the 12v battery, at what intervals should the Prius be driven to avoid bad things happening? Scenario: Prius is going to be stored elsewhere so somewhat inconvenient access. How often should I make the trip to drive it?
  6. ColoradoBoo
    ColoradoBoo Senior Member
    952
    626
    Monument, Colorado USA
    If the 12-volt isn't able to be connected to a battery tender, I'd either plan on driving every 2 weeks OR I'd disconnect the 12-volt battery and try to drive her at least once a month.
    Make sure the oil is fresh (changed within the last 6 months) You don't want old, dirty oil sitting in there.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Yes. With a qualification.
    Your need an automatic tender-type battery maintainer. NOT a cheap trickle charger.
  8. sam spade 2
    7,035
    2,788
    2017 Prius c
    They all are. I glanced at the ones at WalMart yesterday and most of them were well over $50.
  9. Mendel Leisk
    38,665
    Definitely. I got the CTEK 4.3 for around $80 CDN, about 10 years back. It's equivalent now I think is CTEK 5.
    Amazon.ca:
    (CDN site)
    Amazon.com:
    (US site)
    ColoradoBoo likes this.
  10. JohnPrius3005
    JohnPrius3005 Active Member
    416
    224
    California and Hawaii
    For what its worth I use cheap Foxsur chargers from China. I've used them for 10 years+ without ill effects. I have about 20 of them for use on various cars, friends, cars, riding mowers.
  11. sam spade 2
    7,035
    2,788
    2017 Prius c
    If those are unregulated trickle chargers, you are damn lucky that you haven't had any problems.
  12. JohnPrius3005
    416
    224
    Copy that. I’m sure these are not unregulated trickle chargers. My point was that an “expensive” charger is not necessary. And my opinion is that the expensive chargers are sourced from China anyway for about 10% of what they are sold for retail.
  13. sam spade 2
    7,035
    2,788
    2017 Prius c
    That is no better than a wild guess on your part.
    Have you priced THEM lately.......and/or checked the spec's to be sure ??
  14. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
    Ouch, I have a CTEK 7002 bought 10 years ago, but this guy just burst my bubble.
