Stereo settings
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Sddunn, May 17, 2018.
  1. Sddunn
    Sddunn New Member
    Nanaimo
    2018 Prius Prime
    Is there no way to tune your treble and bass settings on the 11.4 inch screen without the jbl sound system? I just picked mine up yesterday and i can’t find anyway to adjust the settings ?
  2. Tideland Prius
    16,155
    1. Press the bottom right hand corner to bring up the audio screen.
    2. Press "Sound"
    3. Adjust your bass, mid and treble as necessary.
    Here, you can also adjust the Digital Sound Processor (DSP). It's basically just the automatic sound levellizer (audio volume will adjust according to vehicle speed).
    If you need to adjust the climate control, there are two ways
    You can touch the bottom left hand corner to bring up the climate screen.
    or
    there are some common used functions available in the 4.2" MID on the instrument cluster. You can go there by press < or > on the steering wheel until the climate page shows up.
    When you vehicle is stopped, you can pinch-to-zoom on the navigation map. There are also options to show a secondary inset map by selecting the "Options" menu on the top left (it's the icon with the 3 horizontal bars).
    Mark57, mercat68 and EyePrime like this.
