Stereo wiring question
Discussion in 'Prius c Audio and Electronics' started by lewbarb, Jun 25, 2012.
  1. lewbarb
    lewbarb Junior Member
    Carrollton, TX
    I have a Prius C Model One which comes with a 4 speaker stereo system not 6 speaker as on the other models. I would like to put the back speakers in. Does anyone know if they prewired the back speaker area or not?
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Take the back apart and see if there are a couple of wires hanging there. Your gonna have to open it up sometime, especially if you are adding speakers! I am assuming the four speakers you have are 2 tweeters, 2 lo range speakers, or is it 4 of the same thing?
  3. lewbarb
    Carrollton, TX
    Yes I have the 4 speaker setup. I would like to make it a 6 speaker setup. Thanks for the help.
  4. los panda
    los panda Member
    155
    23
    did you end you running speaker wire into the door? i will be running 16 awg wire into all 4 doors;
    it looks like it's going to be HELL running wire into the doors, such a tight space. i am debating removing the doors to make the process easier.
    has anyone ran new wire, or has everyone spliced into the existing wire?
    i'm especially interested in what the op did here.
  5. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i think most people run the new wire into the door. there should be a little wire loom but getting to that might be hard.
