Stft
Discussion in 'Gen 3 Prius Technical Discussion' started by douglasjre, Apr 20, 2023.
  1. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    Is 7% most throttle positions but 14% at wot and high rpms. Any idea what could make it goes up at wot? No error codes, Money Indicated Light is off
  2. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    If the fuel trim is high at wide-open throttle (WOT) and high RPMs, it could mean that the engine is running lean (not enough fuel). This can cause poor performance and possibly damage the engine. One solution could be to check the fuel pressure and fuel injectors to ensure they are functioning properly.
    Other possible reasons could be a clogged fuel filter, a malfunctioning mass airflow (MAF) sensor, a vacuum leak, or a faulty oxygen sensor.
