Sticky brake pedal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tom in Maine, Sep 6, 2017.
  1. Tom in Maine
    Tom in Maine Junior Member
    23
    Searsport, Maine
    I have a 2010 Prius with 163k on it.
    The brake pedal seems to stick. Once coming to a complete stop, the pedal does not usually retract and the brakes seem to drag until the pedal comes back up.
    I can usually lift the pedal about 1/2" or so to retract it.
    If I lube the pivot points at the pedal, it seems better for a couple uses, but if I brake hard, it comes back.
    I cannot get a clear understanding of any interference from the system like the stroke simulator, if that is in play here.
    Wondering about lubing inside the boot to the master cylinder shaft.
    The braking is fine and there is ample resistance and stopping. The pedal just is sticky and the brakes do drag until the pedal is lifted back or the car moves a bit and it then comes out of this.
    My Former Toyota mechanic friend has not come across this one. Hope someone here has.
    Thanks,
    Tom
    49,412
    not sure if it comes into play, but might be worth checking your 12v. no dash lights?
  3. Tom in Maine
    23
    Searsport, Maine
    No codes, nothing odd. Will double check voltage.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Original brake pads? Had a servicing done recently? Level of brake fluid in the reservoir?
  5. Tom in Maine
    23
    Searsport, Maine
    Just through the shop for a state inspection. My mechanic loves to spend my money. Nothing overtly wrong needing attention.
  6. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    What does a state inspection in Maine consist of? Did you have to have any work done prior to the state inspection? Any history of accidents? Original owner?
  7. Tom in Maine
    23
    Searsport, Maine
    All Brake components. Car is new to me. No history, but nothing obviously repaired. Not a rebuilt title as with a salvage vehicle.
    The only issue is the pedal is not returning to its original position. Once it is retracted everything is okay. I am pretty certain this is
    in the pedal mechanism.
    I sell used Priuses for a living, so I have laid hands on a lot of issues. This one is puzzling.
  8. ChapmanF
    15,534
    What happens if you take out the clevis pin between the brake pedal and the pushrod? When the brake has been pushed and gets stuck, and you pull the pedal back up, does the pushrod follow it back? In other words, is it the pedal binding, or the master cylinder?
    I know I've been skeptical of the 12-volt-battery-as-root-of-all-problems school of thought before, but if bisco can explain how low battery voltage is going to make the brake pedal or master cylinder pushrod physically bind, I might have to admit defeat.
    -Chap
    bisco and GrGramps like this.
  9. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Brake pedal free play? Return spring?
  10. bisco
    49,412
    I would, but it's above my pay grade.:cool:
    Raytheeagle likes this.
  11. Tom in Maine
    23
    Searsport, Maine
    Had my mechanic give it another go. He lubed the hell out of it but it is still a little sticky.
    I am going to get a slightly beefier return spring. This seems to be the issue. It is now less constant than it was.
    We'll see.
  12. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    I would check the caliper pistons to see if its stuck or seized...
  13. bisco
    49,412
    agreed, and double check the 12v.;)
  14. WoodyGecko
    WoodyGecko New Member
    Colorado
    Having the same brake pedal issue with my 2004 2nd Gen Prius almost 206k miles.
  15. Mendel Leisk
    38,682
    I'm wondering too, if it's due to neglected brake maintenance, and the pedal's behavior is just the canary in the coal mine? Not sure though.
    NutzAboutBolts likes this.
  16. Michael Mann
    Michael Mann Active Member
    165
    408
    Bay Area, CA
    Old thread but I’m having the same issue. Spring return looks good, brake fluid, nothing seems to be leaking. This one has me stumped...
  17. Tom in Maine
    23
    Searsport, Maine
    We wound up replacing the master cylinder with a used one.
    Michael Mann likes this.
  18. FuelMiser
    FuelMiser Senior Member
    1,298
    885
    Monument, CO
    Thank goodness it wasn't the 12V!
  19. Skier
    Skier New Member
    Boston
    Hi. So what is the solution? I have the same issue with my 2010. I almost constantly have to pulll the brake pedal back up with my left foot.
  20. Skier
    Skier New Member
    Boston
    Did this solve the problem?
