sticky spiral cable / "clock spring"?
Discussion in 'Generation 1 Prius Discussion' started by ChapmanF, Oct 3, 2014.
  1. ChapmanF
    15,579
    My car has a new sound. It happens after making a tight right turn, while straightening the wheel again, a slightly delayed little "schnrff" from behind the wheel, as if the spiral cable gets wound up during the turn, sticks a little bit, and then schnrffs back all at once to its mid-wound state.
    Were these originally lubed with anything?
    -Chap
  2. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    Chap, I see Taurus site, many complaints on white lube drying on the clockspring, remedied with WD-40......All respondents said the sound got worse with cold, I wonder if yours gets quieter on a rare warm Indiana day.
  3. ChapmanF
    15,579
    Robert,
    Ever been to Indiana in the summer?
    (I shouldn't really say anything this year, it was very mild and pleasant almost all summer, owing to a strange displacement of the Jet Stream down towards Louisiana somehow.)
    -Chap
  4. ChapmanF
    15,579
    Finally took the spiral cable out. Opened the housing, unwrapped the whole length of ribbon cable and wiped all the ex-lubricant off.
    Looked carefully all up and down the length of cable for any spots where the insulation might look worn and be on the way to causing the "horn honks turning left" kind of problem. Did not see any visible wear. Getting to it within 6 or 7 months of noticing the schnrff sounds seems to be soon enough.
    I have to guess that people who arrive at the honks-turning-left stage might have been ignoring the friction sounds for a long time.
    Sprayed both sides of the cable and all the inside contact surfaces of the housing with Elmer's Slide-All (a dry Teflon concoction that remains after the light hydrocarbon carriers quickly evaporate).
    So far, in a couple short jaunts around town, no more schnrff sounds.
    -Chap
