Sticky/sticking fan button solutions?
Discussion in 'Gen 3 Prius Main Forum' started by AmazingFacts, Aug 25, 2021.
  1. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    The fan buttons, both to increase and decrease fan speed are sticking and seems like the spring on the back side is getting weak. I tried using silicon lubricating spray and pressed the buttons a dozen or so times hoping the lubricant will work it's way in, but buttons are still sticking. Anyone know of any fixes for this?
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    Our buttons do the same thing. Once I caught on to what they were doing, I got into the habit of feeling them more carefully to ensure the buttons returned to the neutral position before I let go.
    AmazingFacts likes this.
  3. Pdaddy
    Pdaddy Member
    160
    49
    Adjust the temp on the steering wheel instead of using the fan speed button.
    SM-G960U ?
  4. ChapmanF
    18,571
    My off or auto button will stick sometimes.
    It's often the case with such things that there's a factory-installed lube that gets a bit gummy. Sometimes just spraying a new kind of lube over the gummy stuff may help a bit but not be as effective as hoped.
    If mine gets to the point of really annoying me, I will probably remove it from the car and see if I can disassemble the buttons from it on the bench, clean them of any former substances, and then spray them with perhaps Elmer's Slide-All and reassemble. But it hasn't annoyed me that much yet.
  5. bisco
    52,407
    how does adjusting the temp on the steering wheel help with changing fan speed?(n)
    mine has been sticking for a year or so. i also have not been annoyed enough yet to do anything.
    if i'm careful, and press in the right spot, it doesn't stick.
    i may try some contact cleaner someday
    ref=asc_df_B00006LVEU
  6. ChapmanF
    18,571
    I'm fairly sure the stickage involves the plastic buttons, not the contacts beneath them. Depending on what sort of contact cleaner, I might be careful about not getting it anywhere but contacts.
  7. bisco
    52,407
    maybe just an alcohol swab
    #7 bisco, Aug 26, 2021
  8. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Great thanks guys.
  9. socal13
    socal13 livin in the foothills...
    267
    Altadena CA
    Mine does the same thing. If it sticks just tap the opposite one to pop it out.
