Stiff suspension, feel every bump
Discussion in 'Gen 2 Prius Main Forum' started by Gastiboy, Sep 25, 2023.
  1. Gastiboy
    Gastiboy New Member
    I have been gifted a 2005 Prius. Ride feels stiff when I go over uneven road like railroad or cracks. It’s like having low profile tires. Is this a common ride quality on the 2nd gen Prius?
    49,388
    what car are you coming from?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    Check the tire pressures. Many owners bump the pressures way up to get slightly improved MPG, but it makes a significantly more harsh ride experience. If they're high, bump them down to the 32-35 range and the ride should soften up a LOT.
  4. Tideland Prius
    16,127
    It doesn’t have the best suspension. Basic McPherson’s up front and a semi-independent torsion beam in the back. It could also be because of worn parts in the suspension. But yes it’s wasn’t super comfortable when new. Check the tyre pressures. They do have a noticeable impact on ride quality on a Gen 2.
  5. Gastiboy
    Gastiboy New Member
    32 psi on all wheels. Did replace the front struts and sway link. It’s still the same. Wasted $700 bucks.
  6. Meter guy
    Meter guy Junior Member
    27
    I live in florida where it gets really hot in the summer. ive had my 09 prius since 14 and have noticed something.
    when i keep the tires at 35, and happen to drive a distance on the interstate or other similar road, i have damaged my tires due to the internal pressure rise from road temp, one time when i noticed this the tires internal temp was upper 40s right when i noticed it. they start separating and i get a thump thump thump.
    i nolonger keep any of my tires at 35, now I keep at 32 and have not had a single tire separate since.
  7. bisco
    49,388
    Where do you live again?
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Sorry.
    It IS a small car.
    Get used to it.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    I replaced all 4 of my struts with KYB's at 70,000 on my bought new 07. Only difference it made was the steering effort was much lighter since i replaced the strut steering bearings. Exact same stiffness. Big waste of money.
    Its the hardest hitting stiffest little car I have ever owned or driven in. To me it was shocking when brand new how hard it hit road imperfections but that was made much worse by the Goodyear Integrity LRR tires that came on it stock which are the worlds worst tire.. A LRR tire is a very hard tire. That's how they achieve RR.
    Try to push the front end down at the front quarters. Try as hard as you can. It wont budge.
    As i got older and had back surgery neither my wife or I could stand it and sold the car. The seats are awful too. Its an engineering marvel when ti came out a very reliable car but sweet jesus does it have a bad ride.
  10. bisco
    49,388
    funny, i came out of an 02 taurus for my 04 prius, and i never really noticed. maybe because i was just in such awe of the prius hybrid synergy drive :cool:
  11. douglasjre
    douglasjre Senior Member
    1,858
    647
    Orlando, FL
    Check your alignment
    Who's the manufacturer of the struts
