Still confused about Pulse & Glide
Discussion in 'Gen 2 Prius Fuel Economy' started by Aaron, Apr 13, 2008.
  1. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Yes, I've done a search on P&G, but I'm still feeling a little confused.
    I have a 2008 with 1,200 miles on it and I'm averaging about 47 MPG right now. Not too shabby, but I've been reading of 80-100+ MPG so....
    I would like to see more MPG (of course) in my daily commute to work, but I'm unsure if I'm applying the correct P&G method.
    How should I drive my Prius when my distance to work is 18 miles one way and my average speed is about 50-60 MPH on a country road?
    From what I gather I should "stomp on the gas until I reach around 40 MPH....let off and and SLOWLY tap the gas until I reach the desired speed b/t 50-60 MPH...then GLIDE slowing down back to 40 MPH again?" Did I get that right? Wouldn't that make the guy behind me angry?
    Here is what I was reading:
    "You want to accelerate up to a maximum of 40 mph in the “Pulse†phase, begin the “Glide†phase and coast down to a lower target speed. Once the lower target has been reached, you want to re-initiate the “Pulse†phase, re-accelerate back up to a maximum of 40 mph and repeat when and where applicable."
    How do I apply this to my daily commute as I described above?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Concepts you're missing:
    1) True gliding is only possible at speeds below 41mph.
    2) If you want to try P&G above 40mph you have to learn to hyperstealth glide....a no arrows (or yellow arrow from battery to wheels only) condition on the ENERGY display, but underneath the ICE is actually spinning. This is MUCH harder to achieve than a true (sub-40mph) glide.
    3) There is no "stomping". It's a moderate acceleration up to your target speed. If you're any good at engine sounds you, ideally, want b/w 1700-2300rpm. This is constant for any part of your range of speeds.
    4) Finally, if it's a country road you should consider going slower if at all possible. If you can keep your speed to a max. of 50 rather than 60 your mpg numbers will climb dramatically.
    So, if I were you I would do moderate acceleration up to ~49-50mph let my foot off the pedal than very gently ease the pressure back on while letting speed drop off and searching for that hyperstealth glide. Let the speed drop as far as you can tolerate...if you can't tolerate to the 30s range then do not let it drop below 42 or you risk the ICE shutting down then having to restart again (energy waste) as you go back into the next pulse to your top speed (50).
    Clearer?
  3. bwilson4web
    16,012
    You might consider another approach, if the route permits:
    • 1-2 miles - speed about 25-30 mph while the vehicle warms up
    • 14 miles - set the cruise control and enjoy the ride, speed of no more than 65 mph
    • 1-2 miles - speed about 30 mph while the vehicle uses the stored energy to cruise into work
    The advantage is you are just managing the warm-up, letting the hybrid do the cruise and on cool-down, reaping the stored energy.
    GOOD LUCK!
  4. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    First a couple definitions, using the energy screen:
    Pulse = acceleration with arrows from engine to wheels, no battery assist
    Glide = no engine, no batteries, no arrows anywhere
    Coast = engine is on, no batteries, may show 99 mpg
    So Pulse does NOT mean you "stomp on the gas". It's an accelaration, not slow but not hard. Glides generally only work at speeds under 40 mph. Above 41 mph the engine needs to be turning so the electric motor doesn't overspin, so at your speeds, you'll be mostly coasting, not gliding.
    "Pulse and coast" may work for you. True P&G, which never goes above 40 mph, would definitely get people behind you upset. But in either case, this is not the difference between your 47 mpg and 80-100 mpg. At your speeds, some people have shown that cruise control will do as well or better than pulse-and-coast (depending on traffic and other conditions).
    The 80 mpg+ numbers are generally done in special test cases, not real-world commutes (except for Wayne Gerdes, who does get people upset sometimes). But many people (although still a distinct minority) do get over 60 mpg in everyday commutes. Generally they start with putting higher pressures in their tires (>40 psi) and watching traffic, starting to coast before the areas they know they'll need to slow down in. (Generally you want to avoid using the battery). Then they block the grill and add engine-block-heaters for cold weather, hook up a ScanGauge, add EV button, etc.
    With your commute you should be seeing mileages at least in the low 50's in anything above 40'F. Practice accelerating with only arrows from the engine to the wheels when you can, slowing down in advance of using the brakes, and make sure your have tire pressure above the recommended minimum of 35/33. If that doesn't get you above 50 mpg, keep reading the fuel efficiency forum. Blocking the grill in cold weather will help, but it's not worth the effort this time of year.
    (Not everybody should expect 50+ mpg. I based this on your longer commute, your medium speeds, and what I know of your local climate).
  5. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    when i accelrate i can rarely get the engine to just put power to the wheel,s the electric comes on and off all the time. I have been in glide, or super glide though..and its cool
  6. efusco
    19,891
    1,194
    Nixa, MO
    If the middle 14 miles is all highway with few stops I think this concept is just fine and is much as I would do given flat terrain with few or no stops. But I'd drop the speed to 50mph along the route as described.
    I was specifically addressing the pulse & glide question, but certainly the advantages of Pulse & glide diminish at speeds over 40mph and it becomes more difficult to do as well.
    I also agree that keeping acceleration very gentle and speeds slower at the front end is important while doing warm-up.
  7. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    Ironically this is a very similar route to my daily to and from work and this is almost exactly what I do (when possible) on my route to work. The highway speedlimit for my route through downtown Akron, OH varies from 45 - 55 so I just set the cruise at 50 the entire way. In decent weather conditions it is rare that I don't average 60 MPG and on occasion I'll have a good bump to 75 - 80 MPG due to a favorable tail wind. I would love to see what I would average if we didn't use my Prius as the "family" car.
  8. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Here is a little game I created to help me internalize the right go-pedal
    movement to get no yellow arrows to or from the HV battery. It may help
    others too.
    I noticed that even under even, steady acceleration sometimes the yellow
    arrows went into the battery. Then moments later, they switched to going
    the other way. Nowhere had I read what I was supposed to do to get no
    arrows. Many posts talked about the no-arrow state, but none I had read
    told how to achieve it.
    So, I fiddled with very small go-pedal inputs. I found that when the arrow
    was pointing up, into the battery, more go-pedal made it go away. When the
    arrow pointed down and to the left, out of the battery, letting up on the
    So what's the game? To make the needed correction I needed to react
    instinctively, instantaneously, without thinking. So the game is the arrow is
    a snake, let's say a king cobra. When the cobra rears up threateningly, you
    step --very, very gently of course -- on its head and he disappears. If the
    cobra is slinking away off to the left, you hasten his departure by easing up
    on the go-pedal. Kind of childish, but it worked for me.
    For me the game was just an intermediate stage. I soon learned to instantly
    take the right go-pedal response for up or down arrows without consciously
    dealing with the "snake."
    One caution, sometimes the display goes into an indeterminate state for a
    few seconds with the arrows, snakes, rapidly alternating up and down. Just
    hold the go-pedal steady and in a few seconds it settles to up, down,
    or none. Then react as appropriate.
  9. Tdoff1
    Tdoff1 New Member
    122
    VA
    I know this topic has been beaten to death, but I am bear away I go....:deadhorse:. I am getting better at the "glide", but still cannot get the hang of getting to speed efficiently. (only 1 week on the car). My daily cummute is about 30 miles, almost all highway. I am getting 45+MPG NOT using the cruise and feathering the gas on my own. works great when traffic is moving, but stop and go is a pain. I assume that using the cruise control is not as efficient as manual.
    I welcome any info. First tank of gas averaged 46MPG, hope to get better.
    Cheers :eek:
  10. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    If by highway you mean expressway at speeds above 45 MPH, then "glide" is not possible at all, and you probably want to investigate other meathods such as SHM (Super Highway Mode?)
    That really depends on how much effort you want to put into learning and putting into preactice the various manual control techniques that have been found to help. I've found that this time of year without a headwind and no rain, if I use cruise control set at a reasonable speed I am getting better than 55 MPG on a regular basis.
    When I attempt manual control of the accelerator I frequently end up with between 50 and 55 MPG, though occasionally I "get it right" and manage a bit over 60 MPG.
  11. Tdoff1
    Tdoff1 New Member
    122
    VA
    thanks...I am now feverishly searching super highway mode.....:confused:
  12. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    I'll be glad to give you a hands-on driving clinic. Send me a PM if you're interested.
  13. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    I believe the art of accelerating w/o any arrows into or out of the battery is referred to as "dead banding". That might be worth searching as well. The basic idea is that there is an inherent inefficiency related to putting energy into and taking it out of the battery. If you can minimize this, you will maximize efficiency.
    It gets tricky, as I believe there are multiple points on the accelerator where it will dead band. I think of it like this, though I'm not sure if its technically correct. As you increase pedal pressure, the system will first sweep through the "gear ratios" of the "CVT" then click the engine RPMs up a notch and sweep again. The ratio is swept by putting in or taking out varying amounts of energy to/from the battery and adding it to or taking it away from the engine power through the MG and the PSD on its way to the wheels. This is almost exactly the opposite of a "normal" car where you would set a gear ratio, then sweep the RPMs, then select the next gear ratio. In general the lower RPMs are the most efficient, so you want to try and dead band within the first few RPM steps generally speaking.
    You want to find the dead band that gives you reasonable acceleration, without impacting efficiency too much. I usually accelerate on the first rpm notch up from idle on flat city streets, and the second or third when accelerating up hill or onto a freeway.
    Doing all this will definitely help your mileage, but in my experience the single biggest thing you can do is just learn to read the road. I do almost no P&G in the classic sense (bouncing up and down by 10 mph), there is just too much traffic and I don't want to piss people off (and make them waste gas going around me). Instead, I generally just try to anticipate everything as far in advance as possible. If I think the light a block ahead is going to turn red before I get there I will glide or ICE spin as far as I can before braking to the light. This also maximizes the chances that the light will turn back to green before I get there. Then I will dead band accelerate back up to the flow of traffic. I also find that there is a certain amount of play in the pedal over which it will maintain the same speed but get different instant MPGs. I attribute this to the same "gear ratio" effect as above. So once I reach cruising speed, (usually about 43mph on my commute) I will back off the pedal as far as possible bringing the instant MPGs up as high as possible while still maintaining or nearly maintaining speed. Doing this I've gotten as good as 65mpg, and typically 57-78mpg on crowded fast city streets with heavy traffic. When I have to commute on the interstate I just set the cruise at 55 and forget about it. Usually I still get 53-55mpg.
    Good Luck, and keep reading and experimenting! Ultimately you have to just try a bunch of things and see whats works best for your specific drive & climate.
    Rob
  14. Danny Hamilton
    926
    94
    Sorry, didn't have a link handy when I posted my comment before.
    There's a nice long (121 comments) discussion about SHM over at CleanMPG.com:
    New Prius - "Super Highway Mode" Technique (SH). - CleanMPG Forums
    SHM requires adding a gauge to the Prius that will report IGN. A common source for this information is the ScanGauge which plugs into the ODBII port.
  15. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Deadbanding is great in theory, but difficult and unnecessary to hold in practice. As long as acceleration is fast enough to avoid electric-only, and slow enough to keep ICE out of inefficiently high RPM ranges and avoid electric "boost", you'll be OK.
    For those without added instrumentation with which to monitor RPM, I suggest keeping instantaneous MPG above half the vehicle speed during acceleration. This keeps things simple and generally will keep you below 2400 RPM.
  16. M. Oiseau
    M. Oiseau 6sigma this
    270
    Tulsa, OK
    Use JimboK's acceleration advice and drive as if you have no brakes and you'll see a significant bump in your MPG numbers. :bump2:
    You can add P&G, roller-coaster, etc. later.
  17. Aaron
    Aaron Member
    260
    Monroe, Ohio
    How do you not get run-over doing 55 MPH on an interstate? It's 65 MPH minimum where I live.
  18. Danny Hamilton
    926
    94
    States don't all have the same speed limits, and they even vary within a state.
    Here in Illinois the posted minimum is 45 on all Interstate expressways. However, the maximum is 65 in some areas, 55 in some areas, and in a few places the maximum is 45.
  19. richard schumacher
    7,664
    1,043
    United States
    Short path zen:
    - Accelerate briskly (this uses the engine most efficiently)
    - Gliding (no arrows on "Energy" display) is better than coasting
    - Coasting is better than braking
    - Braking is better than stopping
  20. BlackPri08
    BlackPri08 New Member
    50
    central Indiana
    Aaron,
    I recently found myself settling for basically the numbers you are at; I'd have tank averages in the 50-51 range on a good week. From some things I'd read, I had mistakenly arrived at the same idea of "stomp on the gas...". I reread some of the hypergliding articles, and because of some of the recent interest in Wayne Gerde's Chicago to N.Y trip with network tv in tow, I read his article on CleanMPG, An authoritative source on fuel economy and hypermiling on hypermiling, which corrected my thinking. LIke someone already said , when accelarating, keep the arrows from MG's to wheels off as much as possible. I have a 25 mile commute, a lot of it on county roads. My last 270 miles I've averaged 65.5 MPG on my commute to and from work. Temps ranged from 48 def F on morning drive to 70 def F in afternoon. Here's what I did.
    1. Kept most accellaration with the no arrows from MG's to wheels.
    2. Kept most accellaration with a iMPG of 30 or more.
    3. Slowed down. Most county/country roads have a speed limit of 45mph or less.
    4. Accellarate to 40mph, glide down to 25 to 30, depending on terrain, traffic, etc.
    5. Exercised patience.
    These were not the ideal conditions, and I didn't always execute as I should have. I managed the 65 MPG with other traffic on the roads most of the time and spent a few miles on State Hiways each day, which didn't help. The key for me was slower accelaration. I share this to let you know what is possible in a very practical way without perfect execution or circumstances. I hope this helps!
