Still Making A Sound As I Walk Away
Discussion in 'Newbie Forum' started by mcamp52, Apr 5, 2009.
  1. mcamp52
    mcamp52 New Member
    32
    Central Florida
    I pull into the garage. Put the car in park. Turn off the power. Open the door and walk away. As I walk away the car makes a mechanical sound; a constant, single-pitched sound; a sound sort of like a motor moving something. The sound lasts for about 10 seconds and then all goes silent.
    Am I doing something I shouldn't be doing? Is this normal? Anyone know what this is?
    Thanks for reading the newbie question:confused:
  2. Oddest_raindrop
    Oddest_raindrop New Member
    75
    wisconsin
    There is nothing to worry about that motor running is the coolant pump pumping coolant back into the thermos. Some other noises you might here are coming from the emissions system. You may also here some of the same noises when you start the car.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Oddest has it right. That's the sound you are hearing, and it's completely normal.
    Tom
  4. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    There's also a test cycle in the brake system, which runs the brake accumulator pump. This happens a few minutes after switching off.
  5. qbee42
    18,058
    3,074
    Northern Michigan
    The coolant pump makes a whirring sound. The brake accumulator makes a ratcheting noise.
    Tom
  6. mcamp52
    mcamp52 New Member
    32
    Central Florida
    Wow - thanks everyone. Glad to know the car takes such good care of itself. This forum sure is helpful. I really appreciate the feedback. It's such a relief.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    I'd suggest that you close the door before you walk away. As you have already been told the noise is normal and shutting the door wont stop it, but it is a good idea to leave the doors shut on any car which is unattended.
  8. qbee42
    18,058
    3,074
    Northern Michigan
    Thanks, Pat, for that useful suggestion. Perhaps one of the mods can make it a sticky.
    Don't you have some snow to shovel?
    Tom
  9. richard schumacher
    7,663
    1,038
    United States
    I think that's what he was doing :_>
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep. If the OP wants to repro the ratcheting noise, just pump the brake pedal a few times. It'll do it even w/the ignition off.
  11. mathan
    mathan Junior Member
    47
    Toronto
    If I recall correctly, the car can keep the liquid hot in the thermos for up to two days and assists in heating up the car when it's turned on and also helps to provide relatively instant heat when heat is needed in the cabin.
    Quite a neat system.
  12. Politburo
    Politburo Active Member
    971
    208
    There's a list of 'unusual but normal noises' somewhere in the manual. In that list, I seem to recall there is an item that says the fuel system will perform a leak check about 4 hours after the car is shutoff.
    Has anyone ever witnessed/heard that one? I'm way too impatient to do it on my own.....
  13. qbee42
    18,058
    3,074
    Northern Michigan
    Yes. It's another pumping sound.
    Tom
  14. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    It reads like this:
    1. MMMMMMmmmmmmm
    2. Phffft phffft phffft
    3. Ekkie Ekkie Ekkie Ptang Zoo Boing
    4. Ni!
    5. swish swish oompa loompa chitty chitty bang bang
  15. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Knowing Mr. Sparks as I do, :loco: I don't think it was snow in that shovel . . .
  16. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    IIRC, it's 5 hours and the car came w/a tag briefly discussing this.
    Yes, I've heard it when in the garage. IIRC, it's a fairly soft electric motor running (buzzing) whir/buzz sound. It runs a LOT longer than any of the other noises on shutdown. I've never waited in my garage until it stopped so I don't know off hand how long it runs, but it's probably in the order of at least several minutes.
