STILL NO Fix for Gas Fill-up Problem???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by OZ132, Jun 19, 2009.
  1. OZ132
    OZ132 Member
    170
    Northern Indiana
    My brand new Generation III 2010 went down to 3 Bars on the "Gas Gauge" and when I tried to fill the tank, the pump Pops Off after each half gallon I put in. Got it up to one bar less than full, only by "Forcing" it. What's up??? This is NOT acceptable.
    After 10 years, still no fix for the bladder problem??? Or is it just me?
    :rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused:
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    There is no bladder in the 2010 Prius. Period. Any filling problems are unrelated to the old bladder issue. Perhaps the title of this thread should be "New fill-up problem with 2010s".
    Tom
  3. psu77
    psu77 New Member
    29
    Jacksonville FL
    I've had that happen in other cars. I'm not sure if it is the pump or air in my tank.
  4. bwilson4web
    15,389
    <SIGH>I would put together a picture essay of how to fill up the tank ... but it will take about two or three weeks before I need to go again.
    2 people like this.
  5. john1701a
    john1701a Prius Guru
    12,748
    5,243
    57
    That's a just pump problem, nothing to do with Prius.
    If you ever encounter one again (they have to routinely be replaced), take advantage of EV and finish filling at another.
  6. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    I have had this issue. It is possible that the underground tanks need to be "burped." Try another station. I highly recommend a Conoco Phillips station if one is available. (Disclosure: I am a shareholder). :D
  7. john_dough
    john_dough New Member
    75
    "It's Deja-vu----all over again."
    Yogi Berra
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  9. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Huh?... What?...
    But I thought the Gen II bladder-burp was a feature, not an issue.
    :brick:
    Uhh... er...
    Yes, I'm awake. I was just "resting my eyes." :faint:
  10. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    If it happens at multiple pumps or stations, I'd have the dealer look at it.
    I had a Chevy minivan that had a similar problem. Turned out that the tank had a "baffle" inside to prevent the fuel from sloshing around. It had broken loose, and was partially blocking the filler neck opening in the tank.
    The dealer replaced the tank, and that fixed the problem.
  11. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    So there is no bladder anymore, but why is there a rubber "seal" at the filler neck still? This seal made sense to me if there was a bladder because I thought it kept the bladder from being air filled. But with no bladder this seal would allow air pressure to build up in the tank as it is being filled wouldn't it?
  12. qbee42
    18,058
    3,073
    Northern Michigan
    The tank vents to the outside through a vapor recovery system. This keeps hydrocarbons out of the air while allowing pressure to equalize.
    Tom
  13. OZ132
    OZ132 Member
    170
    Northern Indiana
    Guess you're right. Only happened the one time. Last 3 tanks, no problem.
    I was too quick to criticize. Sorry!
  14. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Your problem is due to back pressure while filling the tank and an over sensitive pump nozzle. You gotta bear it out.
  15. OZ132
    OZ132 Member
    170
    Northern Indiana
    Thanks. I was stupid. Much too quick to jump to conclusions. I embarassed my self. :(
  16. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I only ever had problems filling my 2006 once and it was a pump problem. Right from the start the pump would shut off immediately no matter how gently I squeezed the handle. I went inside and notified the attendant. She gave me instructions to pull the pump all the way back so it's just barely entering the tank filling nozzle and then slowly squeeze the handle and it should begin to pump just fine, then ease it back into the filler nozzle while pumping and it worked. Must have just been a buildup of pressure in the tank and an overly sensitive pump but by backing it out to where it was barely in at all then easing it in as it pumps it seemed to have released that pressure (at least that's my guess). Never had a problem before then, nor have I since then.
  17. c4
    c4 Active Member
    607
    51
    I'm still running my 2001, but a 2010 is on the horizon, but on my 2001, I got so frustrated by the continual early shutoff from back pressure (and the militant environmentalists out there will hate me for this) that I got an X-acto knife and carefully cut the gasket out of the filler neck, and this completely eliminated the incidences of premature fuel filler shutoff. From the day I cut the gasket out, I've enjoyed easy, consistent fill-ups every single time, no matter the temperature, how empty or full the tank is- it fills up easily and stops when the tank is full.
    It's easy to blame it on "defective" filler nozzles, but when such a large proportion of fillers have the same problem, I would venture that it's probably not the filler.. I was recently in Florida and rented a 2009 Prius there, and I only had to fill the car twice, but both times, at different service stations, including one that was just opened, with brand new pumps and fillers, I still had premature shutoff problems that I could only solve by pulling the nozzle out almost all the way..
    To counter any "environmental" arguments: By pulling the nozzle almost all the way out to fill, you're basically creating an imperfect seal and letting out emissions as well, and you also run the risk that you could have a gas spill, even one drop of which would make moot any reduction of emissions from the gasket.. On the other hand, even if you cut the gasket out, you might get marginally more emissions than by pulling the nozzle out, but it's much safer and if you happen to live in a state where they use vapor recovery nozzles, the boot around the filler will capture the emissions, again making the gasket rather pointless, especially given the filling problems that it causes..
  18. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    OH MAN you gonna catch he!! now:D
  19. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
    It's a slippery slope from cutting gaskets to tossing CFLs in the trash. :eek:
    :p
  20. ctomrun
    ctomrun New Member
    ashland, ohio
    I just picked up my Gen III out of state and drove 173 home. So, I filled up at my local station. Had the pump on auto and it filled with no issue. I topped it off and only got 1.3 more in it. No problemo !!
