Stock LED headlight plastic cover
Discussion in 'Gen 3 Prius Accessories and Modifications' started by freedom1725, May 5, 2019.
  1. freedom1725
    freedom1725 Member
    74
    146
    Palo Alto, CA
    hey guys
    Bad news. I’ve broke my stock led headlight’s plastic cover due to accident. The headlight still works fine. Just wondering if it’s possible to bake the LED stock and my old halogen assembly n swap the plastic cover.
    Thanks for the help fellas.
  2. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    It should fit just fine.
    I haven't looked at a 2010-2011 LED headlight up close, but the only difference in the clear plastic on the halogens vs. the 2012-2015 LED headlights is that the halogens have a plastic fin running along the inside edge, near where it meets the hood. So, your headlights won't be exactly symmetrical anymore (if the 2010-2011 LED don't have that fin), but it's small enough that probably no one will notice.
    #2 Vman455, May 6, 2019
  3. freedom1725
    freedom1725 Member
    74
    146
    Palo Alto, CA
    Thanks for the details. I noticed those little fins too. I’ll probably swap both left and right covers.
    It will be my very first time baking headlights. Are there any things I have to pay attention to when I bake them? Especially for the LED lights.
    By the way, I’m having the 12-15 ones.
    Thanks again.
  4. Vman455
    534
    551
    The Middle
    Just make sure you get all 6(?) of the screws out before you start pulling it apart. I think I baked mine for 10 minutes at 215 F and the adhesive was nice and gooey.
    freedom1725 likes this.
  5. freedom1725
    freedom1725 Member
    74
    146
    Palo Alto, CA
    Thanks. Any recommendations for the glue that applies after put the cover back together?
    I also need to fix a broken tab. Any suggestions on which glue I should get?
    Thanks again.
  6. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    Request for close up photos of the dissembled pieces, I'm thinking of baking mine also thanks.
