Stopped working after oil change?
Discussion in 'Prius v Technical Discussion' started by jem07, Sep 3, 2022.
  1. jem07
    jem07 Junior Member
    LA
    Help Please. 2012 Prius V 5 Took it in to Valvoline yesterday for a regular oil change and there was confusion resetting the oil change light. Next it was slow to start in drive and go - thought I was stuck there but it turned on fine and drove home. Husband drove it a block or 2 and it stalled out. He said the engine sounded like it would fall out. BUT it reset and he drove it back. Have not much to go off for a sudden issue. Will get codes run BUT does this sound familiar? Bad fuel? Oil issue?
    Unrelated? Horn recently stopped working. There was a fuel sensor repair covered by a recall that was fixed last year by Toyota.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,974
    4,716
    Texas Hill Country
    Check the oil level to be sure it did not all leak out from the filter not being tight or the drain plug leaking. This is the only scenario the oil change guys could be responsible.
    Sadly, these cars sometimes blow head gaskets and run terrible for awhile and then it will run smooth again, often for the rest of the day and sometimes for many days. If this is the case, the cycle will normally repeat only when the engine is cold UNLESS the engine is losing coolant from the passenger side reservoir. This can then be an advanced head gasket issue.
    There are normal spark plug or coil issues that can cause severe shaking. But those issues don't reset themselves and allow normal operation.
    In any case, the best thing to do is to find an independent hybrid shop.
    scona and Tim Jones like this.
  3. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    What and where is the ‘oil change light’ on a 2012 Prius v Five?
    Tim Jones likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,915
    Columbia, SC
    It would be interesting to check the oil level. Maybe too much oil, then getting sucked into intake system ? Used to be a lot of similar problems like this when Gen 2s were getting overfilled with oil.
  5. rjparker
    7,974
    4,716
    Texas Hill Country
    The 5k mile maintenance light.
  6. bisco
    49,488
    lesson: never go to quickie oil change places
  7. rjparker
    7,974
    4,716
    Texas Hill Country
    Based on what?
  8. bisco
    49,488
    too many horror stories
  9. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    Based on PQIA Oil analysis of several and my experience of having a vehicle pretty much destroyed by one putting the wrong fluids in the rear end, transmission, and oil. But their excuse was “that’s what our book called for” and our attorney saying “good luck”. NEVER will another one of my vehicles ever enter one of those bays! Ironically, it was in the Texas Hill County!!!! LOL LOL!!!!’
    Tim Jones and GregC1979 like this.
  10. Air_Boss
    3,952
    1,083
    New Yawk
    Never seen it, though I change at 3,000 miles.
