Storage? How long and how?
Discussion in 'Gen 3 Prius Technical Discussion' started by OZ132, Jun 3, 2009.
  1. OZ132
    OZ132 Member
    170
    Northern Indiana
    How long can I store my 2010 without doing damage to the traction battery? What precautions should I take if not driving it for a month or more?
  2. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    No the traction battery will not be harmed.
    Keep it in the garage of course. Next you might want to get a battery charger for the 12v batt. For my 2007 the manual states to trickle charge at no more than 3a hr. SKS with the 2010 I'm not sure, but turn it off. I don't own a 2010, but in general it should be the same guidelines
    the traction battery will be fine for just a month, no worry. The 12v could use a little trickle charge though, won't hurt anything. If you don't have a smart charger for 12v/6v batteries, Honestly I would just garage it and forget it. If it's a major concern perhaps have a friend or somebody trustworthy come by and drive the car a couple of times during the month.
    vector smart charger
    http://www.battery-rechargeable-charger.com/vector-VEC1087C-car-battery-charger.html
    black and decker and other brands out there aswell. I own the Vector, it works well.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    As I recall the hybrid system battery (the NiMH high voltage one) will be fine for at least six months of non-use - it's in the owners manual.
    As many will tell you, the 12V lead-acid battery -can- fully discharge if left parked for long enough. This can be any time between about 3 weeks and two months, depending on battery and owner, it appears.
    You have several options here:
    1. Disconnect the -ve terminal of the battery in the rear of the car when you are parking for several months. Note that if you do this and close the rear hatch you will have to crawl over the rear seats to release the hatch - it's an electric lock using the 12V battery. You -could- energize the car from the boost terminal in the underhood fuse box with another battery and then open the hatch in the normal way.
    2. Purchase a "battery tender" and install the "pigtail" in the underhood fuse box. You then plug in the battery tender and connect it to the pigtail when you leave the car for several months. It will not overcharge the battery, won't damage the cars' electronics, and will keep the 12V battery fully charged. It -will not- have any effect on the HV battery (won't keep it charged etc). So you still have the limitation of that battery's storage time.
    3. Have somebody you trust run the car each month for an hour or two. This will bring the HV battery back to the cars' preffered charge level and will charge up the 12V battery. You don't have to drive the car to do this, just put it in "ready" (with an open garage door of course). The engine will run to warm up the cat, then when it is needed to charge the HV battery. The 12V battery charges from the HV one. I wouldn't do this for more than about four months. You'd want to have someone drive it after that, to ensure the engine gets up to full operating temp to boil out the condensates from the oil.
  4. mobi3944
    mobi3944 New Member
    ok
    Thank you for your sharing!
  5. greylar
    greylar New Member
    283
    38
    Montana
    On page 49 of the manual it talks about the smart key disable. On the GII you had to manually turn off the smart key if you were going to be gone for a period of time. Now it automatically does it if you don't enter the vehicle for 5 days or more. So there shouldn't be as much worry. I would probably disconnect the battery if it was going to sit for more than a month.
  6. Jay C
    Jay C Member
    72
    36
    TN
    Now I'm a bit confused. It was my understanding that there was not a separate 12V battery, it all uses the traction battery on GenIII. True or false?
    Jay
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    False - 12V battery jumpstarts the computer and energizes the relays to turn on the 201.6V HV battery to the inverter.
  8. OZ132
    OZ132 Member
    170
    Northern Indiana
    Since the 12 volt battery doesn't "crank" the engine, I'm surprised it is as big as it is?
  9. David Beale
    5,963
    1,981
    Edmonton Alberta
    Well, most owners want it to be bigger to lengthen the time the car can be left unattended! It's about 30 A-Hr now. Many of us think it should be a 50 A-Hr deep discharge unit (like the Optima yellow top size 24 unit - hint hint). It would be nice to have enough room to offer that as an option.
    Heh, an Optima option! :)
  10. David Beale
    5,963
    1,981
    Edmonton Alberta
    Actually the GII would also shut off the SKS automatically, only not until 16 days of non-use.
    Another little known fact that is in the owners manual. ;)
  11. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    I'm now on my third deployment where my Prius stayed behind in the garage. Each time I've disconnected the 12V battery negative cable. Each time I've come home, reconnected the cable, and had the car start right up. The traction battery charge was always at the maximum amount of blue bars, too.
    2 people like this.
  12. OZ132
    OZ132 Member
    170
    Northern Indiana
    It looks to me like a slightly (physically) larger battery would fit in the space?
  13. David Beale
    5,963
    1,981
    Edmonton Alberta
    You can get the small Optima (38 A-Hr) in there but the "standard size" Optima (size 24 I think) is 1" too big. Either way you will need terminal adapters or you will need to change to "standard size" battery terminals. The adapters are available from an outfit that sells them and the Optima small battery for the Prius. When I looked at the GIII it seemed the battery is the same as the GII. But it was a "prototype", so a current owner may want to have a look at the production car.
    There is a pinch weld on the floor of the space that limits the width of the battery as I recall.
  14. PetersPrius
    PetersPrius New Member
    64
    East Hampton, NY
    Has anyone actually had experience with storing the GEN III for more than a month? without disconnecting anything?
    Please only respond if you own a Gen III as previous models are very different. Thanks
  15. Tideland Prius
    16,073
    I don't see how the suggestions above are not valid (Esp. since it was asked in a Gen 3 forum) plus how is it "very different"???
  16. Benggolf
    Benggolf Member
    297
    53
    Richmond, BC, Canada
    We got back from a cruise vacation and our Prius started without any issues after over a month. The car was parked in a secure covered parking all the time. ;)
  17. Tideland Prius
    16,073
    Good to know. Lights left in AUTO or OFF? Anything special done?
  18. Benggolf
    Benggolf Member
    297
    53
    Lights off. Made sure everything was turned off. :)
  19. F512M
    F512M Member
    415
    Laguna
    Does anyone have a picture(s) of how they've connected battery tender to their Prius?
