Storing a 4th Generation Prius long-term
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Puruisi, Nov 23, 2016.
  1. Puruisi
    Puruisi Junior Member
    Suggested recommendations are around in this forum (and the manual, I think) for storing previous generation Prius cars for long-term. I'd like to know if anyone knows of any changes for the 4th generation Prius. Primarily: should anything be disconnected or disabled? I do not have easy access to a manual.
    49,847
    how long?
  3. Prodigyplace
    11,709
    11,324
    Central Virginia
    CoastRider and RCO like this.
  4. Puruisi
    6 months to a year.
  5. Puruisi
    I already plan to disable both keys (there are manual instructions how to do that) since there will be no reason to have them putting out a signal for that long.
  6. Mendel Leisk
    39,023
    I don't know, are the fobs doing anything if you don't push a button? Anyway:
    1. Inflate tires to max sidewall, to reduce flat-spotting. (Or better, if it's garage stored: raise the car slightly and settle on safety stands.)
    2. Leave the car with a full tank of gas. You can also put in gas stabilizer.
    3. Put an open packet of silica gel in the cabin, maybe a few. Leave one window slightly open, and tuck in a rag, to prevent insect incursion but allow a little air circulation.
    4. Shim the wiper arms with rags, enough to lift the blades off the glass.
    5. Wash and wax the car.
    6. Charge the 12 volt battery, then disconnect the negative cable. Or remove the battery completely from the car.
    CoastRider and Tideland Prius like this.
  7. Tideland Prius
    16,223
    This should probably be a separate thread in the maintenance forum and stickied!
    RCO likes this.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,585
    near Brisbane, Australia
    Remember, if you disconnect the 12V battery, you'll lose some of your settings - the Manual details them.
    Is there no way for someone to take it for a run every few weeks instead of storing? I had someone's car stored here for a few months, on condition that I took it for a drive up to operating temperature every 2-3 weeks. Either way, don't forget to keep your insurance current.
  9. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    The Prius (and any car with an expensive battery) is a horrible car to store long term.
    For about 3 months, the HV battery should be fine. (The Gen 4 is a new battery chemistry, so no one really knows) The 12 volt battery is unlikely to survive 3 months, but disconnected is better odds than still attached.
    Putting it in Ready every month would sure help both.
    CoastRider likes this.
  10. Prodigyplace
    11,709
    11,324
    Central Virginia
    I believe you are supposed to disable the wireless locks on the car so it doesn't keep looking for the fobs.
  11. Mendel Leisk
    39,023
    If you've disconnected the 12 volt you're ok on that front. On that topic too: I've found a fully charged 12 volt battery out of the car (and likely even with just neg cable disconnected) is surprisingly stable. Due to no phantom loads I think.
    #11 Mendel Leisk, Nov 23, 2016
    CoastRider, RCO and alanclarkeau like this.
  12. Senior Bob
    Senior Bob Junior Member
    Pleasanton, CA
    I am new to this forum but have had a Gen 2 Prius since 2008. I had an issue storing it while I was away for several months, didn't do anything the first time and found the battery had discharged so had to jump-start. After that, and looking at forums at that time I got a battery charger and put it on trickle charge and connected it like for jump starting and it worked to keep the battery charged up while I was gone. The dealer told me the smart key system was the drain, but there was no way to turn it off.
    Now I have a Gen 4 Prius, just purchased, and I am facing the same issue, I am wondering if there is a reason I can't use the same method to keep it charged up while away??
    Thanks for any help.
  13. bisco
    49,847
    you can, and it has a bigger battery under the hood now. also, you can turn off the smart key somewhere in settings, check the o/m.
    tai_prius05, RCO and kithmo like this.
  14. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    Can we simply just remove the battery from the smart key fob?
    And I like Mendel's idea of inflating the tires to max pressure. I did that in the past, with a Honda, and the tires were fine after a few months. (on the Prius, I wouldn't know where to put the jackstands, and I don't own a floor jack.)
    Alan has the best suggestion of all… Find a reliable person to start and drive your Prius a couple times a month, if possible.
    #14 CoastRider, Jul 29, 2017
  15. Mendel Leisk
    39,023
    I use a low amperage smart charger, leave it on constantly if the car's going to be idle more than a couple of days. Doesn't hurt to leave it on constantly.
  16. bisco
    49,847
    the car is constantly looking for the fob, that's why they tell you to store it away from the car.
    RCO likes this.
  17. CoastRider
    305
    397
    Yes, I understand that. If we remove the little button battery from the fob, then car can't find it, right? The fob cannot receive the signal from the car.
  18. Mendel Leisk
    39,023
    Not sure about this, but I'd guess if the fob is far enough away that you can't lock/unlock by touch, no battery's being drained.
    kithmo likes this.
  19. alanclarkeau
    7,044
    7,585
    On FOBs - I live alone (with 2 dogs who aren't old enough to drive), so only use one FOB. When I got my Prius 13 months ago, I put the spare FOB into hiding without it's battery. Hopefully, it will start up again fine when/if I need it. Though, if it's like my last car, the one fFOB was still working fine at 4½ years when I sold the car.
  20. bisco
    49,847
    from what i understand, the car searches for the fob, whether there is a fob within range or not. and that's why there car has a switch to shut off sks.
    on the gen 2, it was under the steering wheel. on 3, in the mfd set up. not sure about 4.
    i could be totally wrong though.
    tai_prius05 and RCO like this.
