Storing items in the auxiliary box
Discussion in 'Gen 3 Prius Main Forum' started by Bruceter, Apr 22, 2010.
  1. Bruceter
    Bruceter New Member
    Southeastern Ontario, Canada
    I'm sure someone has already solved this problem. I want to store some items in the auxiliary box under the floor in in the luggage compartment. Things like a spanner, electric tire pump, emergency light, inverter, etc. Items I'll only need for an emergency or flat tire.
    But the box is made of a plastic-type material and is slippery. I expect that my stuff will rattle or go sliding around while I am driving.
    So I bot some heavy duty non-slip shelf liner (as used in RVs) and trimmed to shape. Got it in black to match the box colour. Works well so far. :)
  2. theloop82
    theloop82 Member
    Spanaway, Wa
    I may be the only one, but the first thing i did was take the cover for the "auxiliary box" off and make my trunk 10" deeper and not have to worry about mucking up my carpet. I put a heavy duty plastic tote in there and strapped it in with a bungee cord so i dont have to worry at all about throwing wet, sharp, or dirty items in the back of my clean new Prius!
    2 people like this.
  3. lnj888
    lnj888 New Member
    New York
    2003 Prius
    I
    thanks for sharing ^_^
  4. silverfog
    silverfog New Member
    152
    23
    Raleigh,nc
    Just stuff a towel in there -- comes in useful too.
  5. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    Actually thats one of my problems too.
    They are so cheap not to put anything over that. Maybe they want to sell us accessories for it as well.
    I put a towel but things still slide around. I am thinking about buying a huge gel type of layer to put there so I can put things there without rolling too much and make too much noise.
    The towel didn't really solve the issue.
  6. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    If you store the tonneau cover in the slots provided at the extreme rear of the hatch compartment, the fold-up floor covers and protects it.
    WRT towels, _The Hitchhiker's Guide to the Galaxy_ advises not leaving home without one.
    WRT to _Hitchhiker's Guide_, I haven't seen anyone compare the iPad to it. Did I just miss seeing that, or is it a generational thing?
  7. scottcocoabeach
    scottcocoabeach Junior Member
    Cocoa Beach, FL
    Where do you buy this? Sounds like a great idea.
  8. duffasaurus
    duffasaurus Senior Member
    177
    38
    Charlotte, NC
    The Toyota OEM accessory Cargo Organizer (PT924-47100) works very well without any fuss!
  9. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    Yeah where do you get those heavy duty non-slip shelf liner for RVs?
  10. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I have a few old shoe-boxes with the tops cut off - in between to fill the extra space I have stuffed a small fleece blanket and a rain jacket.
  11. reustis
    reustis Junior Member
    cuba, ny
    2015 Prius v wagon
    you can buy shelf liner at walmart, I got black to match and cut it to fit in the storage area, I also cut a piece to fit into the upper glove box.....works great...
  12. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I use an old wool army blanket, good to have for emergencies also.
  13. bisco
    51,154
    excellent idea! never thought of that. now, we need someone to make an all weather carpet to fit the new configuration.
  14. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    I believe Lowes sells an indoor-outdoor, rubber-backed carpet runner for stairs in a couple of widths and colors. The stuff in nearly indestructable, can be hosed off, and is cheap enough to replace if needed. A little artistry with a utility knife and there you have it.
  15. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    Another option is to get either (1) some of the mesh which is sold to put under throw rugs so they stay in place, or (2) very similar material but not mesh which is sold for lining drawers etc in large tool box carts. They're not "sticky" but do create enough friction to keep things in place pretty well.
