Straight pipe
Discussion in 'Gen 4 Prius Technical Discussion' started by Zed zen, Jul 12, 2021.
  1. Zed zen
    Zed zen New Member
    Maldives
    im bidding on a prius and looks like it has a straight pipe exhaust. The suspension is lowered too. Never hered a prius with straight pipes. Do you think its woth getting this car. Is it easy to revert back the modification if its too loud ?
    Thanks
  2. amos
    amos Active Member
    374
    283
    los angeles
    Did you calculate the cost of parts needed to bring it back to original? How much are you paying for it. Must be a low milage car.
  3. Zed zen
    Zed zen New Member
    Maldives
    It has 72k km on the clock . Not sure about the exact damage caused to the front suspension. I guess to revert back to the stock exhaust system will the most expensive?
  4. Zed zen
    Zed zen New Member
    Maldives
    Some more pictures
  5. bisco
    52,373
    that's a beautiful exhaust, must have been owned by a modder. might be loud, is there a cat?
    Zed zen likes this.
  6. Zed zen
    Zed zen New Member
    Maldives
    Seems to be a straight pipe
    Was owned by “LowStyle” cult guy
    Found some videos on instagram. Very loud when engine is started
  7. bisco
    52,373
    shouldn't be a problem, other than removing and replacing again. here, the cat would be a concern
  8. brenthon
    brenthon Junior Member
    GA
    So, did you buy it? A straight pipe is not really bad if it has a resonator.
  9. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Way too many suspension and exhaust mods for me. I wouldn't trust that it was done correctly personally or that it improved anything
