strange beep or buzz sound after HID bulbs replaced - prius gen 2 (video), lights are dim
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by haxsen, Oct 14, 2023.
  1. haxsen
    haxsen New Member
    remote
    Prius generation 2, model 2007, G variant. I feel the lights are very dim even after replacing bulbs. The video is on youtube /shorts/uv6075EUNco
    (unable to post direct link)
    49,409
    how is the 12 volt health?
  3. haxsen
    haxsen New Member
    remote
    it's replaced recently and is good. The sound started after replacing headlight bulbs. The bulbs are also good, new, just not sure which connection is weak in the headlights.
  4. haxsen
    haxsen New Member
    remote
    Went to the mechanic and he fixed the headlight intensity but the buzzing sound is still there.
  5. Classic Car Guy
    Classic Car Guy Active Member
    396
    114
    Northwest, USA
    follow-up. did you locate and fixed the buzzing sound?
    Could it be your headlight relay or ballast is shorting or acting up? I heard the same thing and since then I don't use the car at nights or not turning on the headlights. Let us know what you did. Thanks,
  6. haxsen
    haxsen New Member
    remote
    The buzz or beep remained even after changing bulbs and ballast.
    Today, I upgraded to LED lights through a local mechanic/electrician, in a way that is reversible.
    Enough of HID bull sht.
