STRANGE Behavior when Turned Off - Help Needed - 2005 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GregAZ, Jan 11, 2010.
  1. GregAZ
    GregAZ Junior Member
    39
    Phoenix, AZ
    So, my 2005 Prius with 120kMi (all my miles) is finally starting to give me some issues .... the latest one is this:
    When I turn off the car, the Check Engine light comes on really faint, and it starts making a beep sound. The car is DEAD at this point, I can't turn it on, I can't lock it, can't do ANYTHING. Then after a while it comes back ON (all on it's own) and it's almost like it's booting. Then I can turn it off and lock it. When I come back, it opens and starts right up. The batteries have never been replaced, and the car is otherwise sound (few niggles that will need to be addressed at the 120kMi service (also needs a new driver side headlight ($700!!!!!))).
    Any ideas on what this can be? Many thanks in advance!
  2. Patrick Wong
    18,198
    6,464
    I'd suggest that you start by replacing the 12V auxiliary battery. It's possible that you might have another issue, but the battery is a good place to start.
    2 people like this.
  3. Ophbalance
    Ophbalance Member
    205
    16
    North Carolina
    What's a good unloaded range for the 12V, specifically for the Prius? I'm seeing 12.1 with the car totally shutdown on the scanguage... but I would expect to see some of these odd issues if that were truly the case.
  4. GregAZ
    39
    Phoenix, AZ
    Forgive the question, but is that hard to do? I am not a total mechanical dufus, just spoiled by the Prius. I have replaced engines in other cars before, but don't even know where the aux battery in the Prius is! I assume this is something I can do myself?
  5. Patrick Wong
    18,198
    6,464
    A new 12V AGM battery fully-charged will measure 12.8-12.9V. 11.9V is discharged. If your Scan Gauge is measuring voltage accurately, then your battery is ~30% charged. The voltage measurement is valid only if the car has been IG-OFF for several hours, prior to measurement.
    Hi Greg,
    The 12V battery is in the hatch, right rear corner. Yes, you can DIY. Remove the traction battery ventilation duct that runs over the 12V battery, and the brake power supply next to the 12V battery, to improve your access to the 12V battery.
  6. Ophbalance
    Ophbalance Member
    205
    16
    North Carolina
    Crap... that's what I thought. I'll have to pull that panel off this week and see what it's reading on the multimeter... unless the post on the front of the car is accurate enough? This'll be the second optima that I'll have bought this year.:rolleyes:
  7. GregAZ
    39
    Phoenix, AZ
    You can put an Optima in the Prius?? Is this recommended? I used Optimas in many other cars and LOVE them!
  8. Ophbalance
    Ophbalance Member
    205
    16
    North Carolina
  9. richard schumacher
    7,663
    1,038
    United States
    The jump post value will be close enough to the battery terminal value unless the car has some abnormal current drain somewhere (in which case the jump value would be even lower, which would be a good thing to discover).
    The Optima does need adaptation. eLearnaid sells a complete kit for this, very nice.
  10. KadensGma
    KadensGma New Member
    I have an 05 Prius and when I started to have " strange glitchy electrical " it turned out to be the 12 volt battery.....simply wasn't recharging up fully...oh I have 133,000 miles hope to replace next October with another one..
  11. GregAZ
    39
    Phoenix, AZ
    Thank you, everyone. Had to jump start it this AM, and when at the dealer, it was discovered that the 12V battery is indeed toast. $150 and my Toyota reliability is BACK! You forget how much you get used to it, until you no longer have it. :)
