Strange Behavior
Discussion in 'Gen 2 Prius Main Forum' started by Stever, Aug 18, 2004.
  1. Stever
    Stever New Member
    Strange Behavior:
    I have all the Australian options (Nav, Phone, etc)
    Dairy of Events:
    Mon: 20,000 Km Service at local Toyota Dealer
    Tue: Prius starts ok, after driving for 5 minutes I press the 'Map' button on the steering wheel with no response. I pull over, stop the car and start the car. No Nav, Climate, Consumption or Audio displayed on the screen. I did get the 'Bluetooth connected' message and the Volume up/down showed when I turned the Radio Volume.
    When I got home I tried the diag screen, no obvious errors or problems.
    When the car started I got the "Prius Splash Screen", then a blank screen for 5 seconds then, the "Consumption" screen with blank Temp, Average & Current values.
    When I pressed the "Map" or "Audio" button I got a message like "Failed to connect to external device".
    Wed: While driving to work the radio started cutting in and out, then the values on the Consumption screen started to appear. The Nav system worked and the Phone connection also. I called the Toyota Dealer and the checked it over and found nothing conclusive.
    I Drove home (45 minute, 30Km drive) with no problems. I went out again and on the way back the radio cut out for 40 seconds then started again. During that time the Nav system did not respond. I went out a second time and while backing the car up the driveway the screen when blank the redisplayed the "Prius Splash Screen" then displayed a "Check the System" Message for a while (40 Seconds) then things started coming good (Nav, Radio) ect. I then tried turning the volume both the knob on the radio or the up/down button worked. I had to turn the radio power off.
    Do I have a Virus?
    Has anyone else had these troubles?
    I plan to keep a camera in the car so I can take pictures of the screen when (if) it happens again. I there anything else I could do the Toyota Dealer?
    Thanks for any help!
  2. LeVautRien
    LeVautRien Member
    379
    New Orleans
    The fact that you had just have the service makes me wanna think that the service people somehow messed it up. I wouldn't know how, but if you had the problems the day after leaving them, it almost has to be their fault, and as such, I would imagine you were entitled to get them to fix a problem of their own doing.
  3. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Sounds like a loose wire with that failure to connect stuff.
  4. Danny
    Danny Admin/Founder
    7,093
    2,107
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Yep, sounds like they didn't plug one of the ECU wires back in all the way.
