strange braking noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chrisengst, May 17, 2016.
  1. chrisengst
    chrisengst Junior Member
    42
    Ithaca, NY
    I bought this 2010 new and have never heard this noise until three days ago. When I apply the brakes lightly, there is a somewhat high pitched noise almost as if air was being released. It is not a scraping noise. It comes from the right? rear. If I break medium hard the noise goes away. It happens warm or cold and doesn't change (or gets a little worse) during course of the day. There isn't regenerative breaking in the rear, is there?
  2. JC91006
    16,482
    8,400
    Maybe it's worn? Metal on Metal?
  3. chrisengst
    42
    Ithaca, NY
    Not what it sounds like. Will check when brakes redone, but think was less than a year ago.
  4. Christian_cool
    Christian_cool Junior Member
    92
    17
    Germany
    Try to Jack up your car and rotate the back wheel s with hand and see if they rotate without resistance. Remember to have the foot parking brake released. Meanwhile check how much your brake disc /pad have been wear down.
    Regenerative braking only happens in the front wheel.
    Hope it helps
    Christian
  5. chrisengst
    42
    Ithaca, NY
    Sounds good to check. We drive on dirt roads 4 times a week, and it has rained a lot. However, rear brakes done and rusty backing plate romoved 5 months ago.
    Christian_cool likes this.
  6. JC91006
    16,482
    8,400
    you probably got something stuck in the calipers/pads. Remove and inspect the braking system.
  7. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    wear clips are probably bent
  8. chrisengst
    42
    Ithaca, NY
    Will check out what I can see this afternoon. Thanks
  9. Mendel Leisk
    38,724
    When I hear "rear brakes done" it has me wondering: did they get the caliper piston oriented correctly. There's pins on the pad backs that are supposed to lock in between the spokes on the caliper piston face. When the parking brake is applied this prevents the piston from rotating.
    If the pin is mis-oriented, or was not solidly seated, the pin may ride up on a spoke. This causes uneven application of pad pressure, rotor scoring, constant drag, all sorts of good stuff.
    For starters, have a look through the spokes with a good light, see how the rotors look. Uniform shiny, or scored? If you crawl under you can JUST see a little bit of the inside face of rotor. Does it look ok? Misaligned piston will evidence as about 50% of the rotor surface being unused/rusty.
    Then follow suggestion above, chock the front wheels, raise the rear (with parking brake off), and see how easy the wheels turn. A slight drag is normal, but it should not be a fight to get the wheels spinning a turn or two.
  10. chrisengst
    42
    Ithaca, NY
    Not knowlegable about brakes. Removed wheel, nothing obvious stuck between rotors and pads. what should I be looking for?
  11. JC91006
    16,482
    8,400
    A high pitched noise would indicate some type of metal rubbing. If there's a wear indicator clip, check if that's rubbing close to the rotor.
  12. chrisengst
    42
    Ithaca, NY
    Okay, so here is where I am at. Jacked up, and only slight drag on wheel. Only slight squeek. Nothing obvious caught. wear seems even on rotor. Am going to go back out and have wife apply slight brake and see if noise.
  13. chrisengst
    42
    Ithaca, NY
  14. chrisengst
    42
    Ithaca, NY
    When wife applies brakes very lightly, no unusual grabing or noise. Think will put wheel back on and take it to garage where brakes done. The guy is very understaning and reasonable, so will have him ride with me to hear noise, and see what he thinks.
  15. Mendel Leisk
    38,724
    While the wheel's off (if it is still) you can check pad thickness. Outside's relatively easy to see, and both sides visible through a hole in the caliper shoulder, edge-on.
  16. chrisengst
    42
    Ithaca, NY
    Pad thickness fine. Wheel back on.
  17. Former Member 68813
    3,524
    981
    US
    did you mean air hissing noise? I get that, but only when I press the brake pedal hard enough.
