Strange change in outside temperature reading
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CaliforniaBear, Sep 13, 2014.
  1. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    This was after a car wash and it "appears" to be recovering. It was 20 minutes after the wash so that complicates matters. However, it reads about 10 degrees (F) low and now the word "Outside" is displayed above the temperature. It used to only show the numerical value. Any ideas?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    How old is your 12v auxiliary battery? Maybe this unusual behavior is a warning your battery is starting to get low.
    If your battery is Ok, you can always disconnect the battery for a while to reset everything.
    SCH-I535
  3. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Mine does the same thing. I think water gets on the sensor. It will be fine as soon as it dries out.
  4. CaliforniaBear
    1,179
    289
    Northern California
    Battery is good. Temp reading seems okay now. Must have been the water.
  5. bisco
    49,448
    why does it even have the ability to display 'outside'? does that mean it is used in another vehicle with more features?
  6. Okinawa
    Okinawa Senior Member
    1,333
    317
    I have a new Avalon. When I run it through the car wash my outside temperature reading changes and is not correct until the sensor dries 20 minutes or so later.
  7. CaliforniaBear
    1,179
    289
    Northern California
    I've been though car washes before with the PiP. I guess the latest on just did a better job :)
  8. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    My PiP has always said "outside" for the outside temp.
    The outside temperature is used by the vehicle to determine whether heat and/or A/C is required (as opposed to just fresh exterior air) to reach the target interior temperature. The exterior temp information is also displayed as a convenience to the driver. This has been the case on every vehicle I've owned for the last 10+ years.
  9. bisco
    49,448
    apologies, i meant the word 'outside'. mine doesn't have that. it only displays outside temp.
  10. bisco
    49,448
    and my reading of the o/p was that the word 'outside' was an anomaly for him, but i'm probably wrong about that.
  11. CaliforniaBear
    1,179
    289
    Northern California
    Well at my age it wouldn't be unusual to not remember the Outside always being there since I often can't remember what I was planning doing when I leave my room and walk to the kitchen. However, I'm pretty sure that the word Outside wasn't always there but is now shown in all caps. In any case it does now seem to be giving a reasonable temperature reading.
  12. bisco
    49,448
    LOL, mine doesn't say 'outside', although, i've always assumed that's what it was. maybe i should get a car wash for the full feature of the display.
