Strange honking sound
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tom1l21, Mar 30, 2009.
  1. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    When I'm at a stop, occasionally I will hear a very faint honking news (as if you were to lightly tap the horn on a gm vehicle). It happens maybe once or twice a day and it is usually only one to three honks at a time. I notice it because I'm always looking around thinking someone is honking at me. It almost sounds like the sound of a dry squeegee on your windshield. Its not my wipers either. They are off when I hear it. Any ideas?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Is the light green by any chance?
    Tom
  3. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    LOL, no. I've even heard it when I pulled into a parking lot and had the car in park for a few minutes.
  4. darelldd
    6,057
    389
    Northern CA
    It is something wonky with the brakes. Many of us have experienced it, and I believe that there was even a TSB on it. It only happens in my car when I'm at altitude - and others found the same thing. Very odd. Since it doesn't happen where I drive the other 360 days of the year, I've decided not to worry about it - but I do know how disconcerting it can be!
  5. magruder
    magruder Average Member
    145
    Colorado
    Are the geese heading north early?
  6. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    What do you mean by altitude as well as technical service bulletin (i believe that is what TSB is)
  7. marzprius
    marzprius Junior Member
    92
    Northcoast
    I've heard this too! Only when I apply firm brake pressure while the car is stopped, like when I'm trying to FAS it. It's infrequent, & I've only heard one, possibly 2 honks at a time. Curious as to what it might be. :confused:
  8. jdenenberg
    jdenenberg EE Professor
    3,852
    1,846
    Trumbull, CT
    2020 Prius
    LE AWD-e
  9. Zythryn
    Zythryn Senior Member
    6,255
    4,254
    There is a TSB out for it. Take it to the dealer, they will first try to bleed the brake lines. If that doesn't work they will replace some gizmo or other. In the case of my wife's car, that fixed it:)
  10. darelldd
    6,057
    389
    Northern CA
    Tom -
    What I mean is altitude... uh... height above sea level. And TSB... Tech Service Bulletin as you have correctly surmised.
    It happens to me when I leave my roughly sea-level city, and drive to higher places... at altitude. And there is a tech Bulletin issued on it - since posted here. Not sure what else I can add.
  11. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    yeah I didn't know if you meant hi or lo altitude. I'll see if my dealership can fix it. If I do nothing about it, will it become a problem later?
  12. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I am going to take my car into the dealership early this week to have them fix my SKS. My car is a 2005 with 83k on it. I know the service bulletins were only for 3 years or 36k, but should I have the dealership fix the problem? I have a 30 day warranty on the car since I purchased it only 3 weeks ago. Will this become a major problem in the future?
  13. Patrick Wong
    18,200
    6,474
    Since brake system performance is not affected by this, it should not become a major problem. However if you can get the 30 day warranty policy to cover the problem, why not.
  14. qbee42
    18,058
    3,074
    Northern Michigan
    My master cylinder starked squeaking last fall when we were out west at altitude. It stopped when I got back to the lowlands of Michigan.
    Tom
  15. oldensign
    oldensign Junior Member
    23
    After much investigation (precious little of it by my Toyota dealer), I narrowed the very brief honk down to the pump in the "thermos bottle" that holds warm engine coolant. The honking noise in my 2005 was typically present when the car hadn't been started for awhile. It's been going on for about 6 months.
    Once I TOLD the dealer where the noise was coming from, they consulted Tpyota and solved the problem.....by declaring it to be a "normal operating noise". Problem solved! :boxing:
    As far as I know, it's not harmful; at least nothing has exploded yet. My wife's 2006 and my sister's 2007 haven't started making this noise yet.
