Strange Issues with 08 Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by kscableguy, May 23, 2009.
  1. kscableguy
    kscableguy Prius Owner
    35
    Augusta, KS
    Been awhile since I have posted here. We bought our Prius new in July of 2008. Due to long commutes, the wife has racked up 25,000 plus miles so far.
    We have notice a few strange issues that that dealership can not explain.
    1) Three times now the MFD has went completely black and when it came alive (2-4 seconds later) all pre-programed radio stations were gone.
    2) The horn will just start to beep. These are short beeps. Maybe 1 sec at most. Only have noticed it when at a complete stop.
    3) The doors will lock, even though the key fob is in the car. The SmartKey system is suppose to prevent this. This has only caused one issue when our son was in the car the wife accidentally hit the lock doors when she got out. If the SmartKey would have worked right, it should have unlocked the doors when she shut her door but this didn't happen.
    I believe this is an electical issue but the dealership says nothing is wrong. I want to get this fixed before 36,000 miles even though I plan on buying the extended warrenty soon.
    Does anyone have any idea's or have had the same probelm?
  2. howardbc
    howardbc Member
    154
    Scottsdale, AZ
    I also have a 2008 bought new in February 2008, but so far I haven't had any of the same problems you're reporting, although my car only has about 9600 miles on it. I would like to know if anyone else has had the same issues or if someone has any idea what might be causing it.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This sounds like a problem with the 12V system.
    Tom
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    +1 on what Tom said.
    Weirdness in the electrical circuits is a classic symptom of a 12v
    battery on the way out. Some posters have reported the windshield
    wipers coming on by themselves, and dash warning light light-shows
    and no-shows as well. IIRC, the car has 7 CPUs and 14 ECUs --
    Electronic Control Units; baby CPUs -- that react differently to reduced
    voltage.
    Typically, the service life of the battery should be ~4 years. But if it
    has ever been deeply discharged and required charging, its life is
    greatly reduced. In this same vein, if the battery was not fully charged
    by the dealer in the pre-delivery check procedure, this also leads to
    shortened life.
    You should consider having the 12v battery removed from the car,
    tested and fully charged before opting for a new battery. A new
    battery from your dealer goes for ~$170 and $90 installation,
    though you can do it easily enough yourself.
    There is an after-market battery, the Optima, that many speak highly
    of as well. Go here for details:
    Prius Optima Aux
    Prius 12V swap
    Hope this helps.
  5. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi ks...,
    I seem to remember some PC posts about the 12V battery clamps not being tightened on some newly delivered Prius. Check, or have this checked out first.
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    donee,
    Good call.
    kscableguy,
    There is also the possibility that the grounding strap -- actually a wire --
    from the 12v battery to the body is loose or corroded.
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    This happened to me and took me a couple days to figure out. lol
  8. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    very interesting. i think patrick wong told me once that if you use the car often, no need to change the battery for a while (meaning years). this is the 12V battery you all are talking about right?
  9. richard schumacher
    7,663
    1,038
    United States
    Yes. If the 12V battery is correctly installed and is not abused (that is, never drained by leaving the lights on) then it should last for four years or more.
  10. kscableguy
    35
    Augusta, KS
    So posted this last year. Dealership fixed the radio by replacing it. They say it was a known issue now. But the horn issue has gotten worse. Seems to only happen when the brakes are being used. If the foot is on the brake, it will just beep once or twice. Its crazy.
  11. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    its not your horn, its your brake actuator
    look up "barking brakes"
