Strange message on display unit...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by toolbox2014, Apr 22, 2021.
  1. toolbox2014
    toolbox2014 Junior Member
    36
    central OC, CA
    When I backed my 2015 Prius out of the garage, the display. seems to be OK. As I drove, the display was alternated between the navigation screen and the attached image every couple of seconds. I did not start the navigation app and I have nothing plug into the USB port. It didn't do anything when I press the "confirm" button. After I shut off the car and restart it after about 15 minutes, the display is working properly without this strange message. Is this one of those glitches that I don't need to worry about?
    49,446
    hopefully:)
    do you ever use the usb?
  3. toolbox2014
    36
    central OC, CA
    No
    49,446
    probably a glitch then, microsoft and all that
    ASRDogman likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    Maybe a dirty USB port causing a partial short circuit? I'd take a look in there with a flashlight to see if it's full of lint & dust.
  6. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    microsoft software runs in the head unit? :eek:
