Strange noise in passenger dash 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mark DePonzi, Dec 7, 2013.
  1. Mark DePonzi
    Mark DePonzi Junior Member
    When I accelerate a strange noise appears to be coming from the passenger dash.
    Sounds like some kind of baffle or low rumble sound it only does make the noise under acceleration.
    And ideas on what I should do to eliminate this noise ?
    I have read in other forums that others have had the same noise .
    Some said it was coming from the AC baffles under the dash.
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    It's a defective right fender clip. There was a TSB on it but I doubt now you could get it fixed under warranty. Some who had it fixed said the dealership needed the car overnight for the repair.
    51,154
    there are a lot of noises in the '10's dash's from plastic rubbing on plastic during acceration vibration.
  4. sklarskyj
    sklarskyj Junior Member
    22
    Boston
    This literally just started happening on our 2010 within the last month. We've only had ours for 10 months now, but I don't recall hearing it at all before.
  5. Mendel Leisk
    40,584
    We've got exactly the same noise, same location, same conditions. Lift your foot off the gas, it goes away. Back on the gas, gently, it's ok. Press down a little more, the buzz is back.
    Would love to know too, what this is.
    (Maybe what phoenixgreg says?)
  6. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    i have been noticing that in my 2010 too for quite a while now. is there any DIY fix for that?
  7. phoenixgreg
    1,157
    291
    66
    Phoenix
    Is this your noise:
    This should be the TSB: T-SB-0064-12. Do a search on this forum to see if it addresses a right fender clip (defective on 2010s).
  8. phoenixgreg
    1,157
    291
    66
    Phoenix
  9. nomad26
    nomad26 Junior Member
    San Jose
    YES THATS THE NOISE
