Strange Noise (not tires)
Discussion in 'Gen 2 Prius Main Forum' started by Frontporch, Nov 9, 2020.
  1. Frontporch
    Frontporch Active Member
    552
    128
    Nj
    I am looking for suggestions for a noise I have that isn't too bad, but I would like to resolve. When I drive I hear what sounds like a tire noise. Comes from the driver front. I rotated the tires and the noise remains.
    It sounds like a faint womp... womp... that speeds up and is first noticeable around 25mph. Becomes a constant noise at 70. Strangely it seems to get a little louder when I swerve left on the highway... which should unload that side of the suspension somewhat, but it is present in almost all cases, turning, accelerating, decelerating, engine on/off. I have also been getting a catalytic converter code. Car otherwise runs fine and gets good MPG. I have noticed an occasional shudder on the engine shutting down, but it is VERY rare.
    My guess from reading is maybe an engine mount has softened and is sharing a vibration... the noise cannot be noticed outside the car.. have been driving windows down lately.
    Thanks for reading.
    Any thoughts?
    52,888
    where did you switch the tire to? noise direction can be difficult
  3. Frontporch
    552
    128
    Nj
    I rotate front to opposite rear and move the rears forward on same side. Not that I can really tell but tire wear looked normal. Maybe just slightly worn more on the innermost part of the tires. Tires are Cooper and have about 25k of conservative driving in them. Lots of tread left
  4. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    front wheel bearing.
    WilDavis and edthefox5 like this.
  5. Frontporch
    552
    128
    Nj
    Take that back!
    Just kidding. If that's the case, I will let it go until it shakes the doors off. I have seen how crappy that job is with a car in the snow/salt areas. Also don't think there is a good aftermarket replacement, but mostly not looking forward to a profanity infused job like that.
    What makes me think its not the wheel bearing is the noise. I would think a wheel bearing would be kind of gravely and wouldn't have much of any noise till a higher speed, say 40 or so where it would vibrate and maybe howl. I would also expect it to change considerably during turns when the loading and stresses are different. But I don't have much diagnostic skills.
  6. alftoy
    1,132
    520
    Just acquired a 2008 Prius with 156,000 miles, on the highway at 60mph have a humm or low buzzing that changes frequency when I lightly move steering wheel left to right. I know its the wheel bearings. Unfortunately its snowing here so its parked for the winter. I did order Timken hubs and bearings, first set from Amazon, opened the one box and it looked used or counterfeit, forgot to take pics. Sent them both back and ordered from Rockauto. What I find curious is I am in Canada and Amazon shipped one from Texas and the other from New Jersey, free. Rockauto looks to have dropshipped from Oswego Oregon where Timken has a distribution center.
    Not looking forward to the wheel bearings, as well as front rotors and pads that are really rusty.
  7. Frontporch
    552
    128
    Nj
    Is that a different thread or yours?
  8. alftoy
    1,132
    520
    Just suggesting my experience with front wheel noise, another way is to jack up front end and rock rim or wheel to see if any play.
  9. Frontporch
    552
    128
    Nj
    That’s true I should have tried to rock the tire when I had it off the ground.
    anyone know if there is a way to jack the front end and allow the motor to spin the tires? It’s a strange question and I wouldn’t ask about other fwd cars
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    The 'womp" "womp" seals the deal on the wheel bearing. Mine sounded exactly like that and it changed at speed. It gets louder pretty fast when they fail. Easy to find which side with the hard turn test.
    Mine was the front drivers side at 36,000 miles. I bought the car new in 07 still have it.
    Dealer covered it under the 3/36 so it was free. Only time in 13 years a dealer has worked on my 07
    Be careful about driving it till it "fails" The way it sometimes fails is it may get the rim so hot there at the end the tire could catch fire. Not as fast as a stuck brake caliber but it will do. Be aware of burning smells.
    Wheel bearing failures are very common on G2's.
  11. Frontporch
    552
    128
    Nj
    From what I have seen, the bearing will fuse to the knuckle with corrosion and has to be air chiseled off. I don't look forward to that. Anyone have a recommendation on a replacement? Any reasonable aftermarket that might get me another 50 - 75 K miles?
    I see on RockAuto there is a brand named Mevotech. It sounds like an off brand, but it has pretty good reviews and a surprising warranty of 5 yrs and 60K miles for only $50.
    Hopefully that project can wait until spring.
    I will make it a point to try the rocking test and even check the heat at the hub from time to time. The noise is not too bad at all. I am a stickler for a quiet car.
    #11 Frontporch, Nov 9, 2020
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    I put new timken hubs (from Rock Auto) on a 240k mile 2005 and it's currently around 325k miles. Was running like a champ until owner bought new tires a few months ago and installers didn't torque the driverside front lugs. Tore the hub up and they installed whatever was available from local autoparts store.
  13. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    A Cautionary Tale:
    Driver-side. front wheel-bearing! Started off as a low growling which seemed to always be there, getting louder as the speed increased. I though it was a sign that the tyres were approaching the end of their useful life (6th season, and down to the wear-bars!) Changed to the winter steelies shod with studded-snows about a week ago. Yowling still there and still quite noticeable even above the roar of the studs. Visit to the local dealer, and the local expert nailed it after a short drive! ½ day (and $800) later, The ChuggyPig is now back to its quiet self, and no danger of the driver-side front wheel falling off in frustration! bearing-1.jpg
  14. Frontporch
    552
    128
    Nj
    Thanks for all the replies. I am going to let things ride for a while and maybe shoot some PB Blaster at the hub a few times prior to spring and then look to operate and swap out both front hubs. I would love to avoid this job, but the car has been otherwise pretty reliable.
    I should add at highway speeds it kind of drones with a sound that reminds me of a jet engine sound from the interior of an airplane, but very faint at this point.
  15. Frontporch
    552
    128
    Nj
    Thought it was a good time to check back. I replaced my first wheel bearing last night and I have to say, it wasn't too bad. The part I dreaded was dislodging the hub. There was a fair amount of corrosion, but it only took me a few minutes.
    The Mevotech bearing went in fine. It looks pretty well made. I think I am going to put on the axle nut and take it out later. I don't want to put on both and then hear a strange noise and not know if or which of the new bearings might be causing.
    If I remember, I will take a few pictures of the other side and the method I use to replace it
  16. Frontporch
    552
    128
    Nj
    Took the entire knuckle off. Not too many bolts. Takes about 20 minutes
    pry off protective ring on back and scrape between hub and knuckle. Sprayed pub blaster and let it sit
    will come back in a while to pound it loose
    WilDavis likes this.
  17. Frontporch
    552
    128
    Nj
    I took off the dust ring and hub bolts off the car and put that all back together before putting the knuckle back on
    I put the knuckle on jackstands
  18. Frontporch
    552
    128
    Nj
    About 10 solid hits with a mini sledge and it’s free. This side, the drivers side, is definitely bad
    thanks everyone
    WilDavis and Raytheeagle like this.
  19. Frontporch
    552
    128
    Nj
    Taking my first drive on the highway since replacing the front hubs and all is quiet and smooth as expected. I have almost 215,000 miles on the car and will try to remember to check back in six months and a year to let anyone know how these bearings are working
  20. WilDavis
    2,493
    2,155
    49
    Nice job! Thanks for posting the pics, now if I need to do the passenger-side, at least I'll have a clue! (…but when that happens, I expect I'll just drop another $800+ at the stealership! (n))
