Strange noise
Discussion in 'Gen 2 Prius Audio and Electronics' started by Lavi2005, Nov 23, 2016.
  1. Lavi2005
    Lavi2005 Junior Member
    israel
    Hello people :) great forum .. I have a problem with my 2008 Prius. Driving routine suddenly has a strange sound reminiscent of a water pump in the glove compartment.
    Does anyone know what is the problem?
    Thanks in advance!!!
  2. Lavi2005
    israel
  3. Lavi2005
    israel
  4. JC91006
    16,482
    8,400
    Take the cabin filter out and see if there's debris in the fan blades under the filter. Probably got a leaf in there
    Lavi2005 and Mgrad92 like this.
  5. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Does the noise change from heat to cool temperature on the steering wheel if it does the top back of a white box there's an actuator need to lube the shaft or replace it. Lube (spray something with graphite or light oil ) fix mine. but you need a long tube at least the length of two red straws will make your life way easier have someone run it up and down and you could see it in the very very back the white box on the left side
  6. bisco
    49,506
    welcome! could be that mice have made a nest in there and you're hearing their bong.
  7. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    he said water pump, not water pipe. but you'd hope they'd share...
