Strange Noises Underneath Driver Dashboard
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jaqueh, Feb 9, 2015.
  1. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    These noises suddenly appeared, and I don't know what is causing them it sounds like a pump or something.
    This is after the car has been running for 4 hours. Climate/fans are off, brake is not pressed, and it's in park.
    49,731
    inverter coolant pump going south?
  3. jaqueh
    341
    199
    San Francisco
    Uh oh. I was about to get the coolant replaced since it's at 130k, and for some reason my mom who was the previous owner never did it at 100k.
    Could it be the water pump also?
    49,731
    i think thats closer to the front and run by the serpentine belt.
  5. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I think I might be hearing some clunking sounds, but it is very faint. My guess is the coolant flow control valve. Maybe try again and this time make the recording from the front, with the hood open, with the phone as close to the noise maker as possible.
    Quote from Yogi Berra: "You can see a lot, just by looking."
  6. jaqueh
    341
    199
    San Francisco
    So I opened the hood, but could not hear any noises other than inside the car. I recorded a new sound that happens after about 1 minute after the car has been turned off. Also, I do get strange "wah, wah, wah, wah" noises when the car is being driven around; it sounds like the car is trying to pump something, but just isn't able to do so. I'm not sure if all of those noises are related
