Strange pitch shift while streaming from phone
Discussion in 'Gen 3 Prius Audio and Electronics' started by Christian Wattengård, Mar 10, 2017.
  1. Christian Wattengård
    Trondheim
    Excel
    So I've seen a few posts about this, but I didn't find any with a solution. I have this problem on my 2010 Prius HD Navi unit and it's really annoying. I've seen others describe it as a slight shift noticeable only to a trained ear, well, both me and my fiance notice it, and it's really annoying and jarring.
    I tried to catch it on a recording to show you
    It's not the best tune to show it on, I wanted to chose one from the youtube archive so the video didn't get taken down. We normally listen to dance and trance, so there is lots of pure synth sounds and such. And this kind of music is completely unlistenable.
    And it's not the phone. I had this problem on both my iPhone 6, and my current Galaxy S7 Edge.
    Did someone find a solution?
  2. Dyjital
    Dyjital Member
    84
    Oregon
    2023 Prius
    XLE AWD-e
    How are you connecting? BT? Aux? USB?
    Typically the whine comes from interference with EMF bleeding into a wired audio cable. When we used to run high end stereos we would go as far to run power down one side of a car and the RCA's down the other side to keep them apart as long as possible.
    Non shielded cables do it as well as poor grounds in aftermarket decks. In other vehicles the whine pitch changes with engine speed (alternator) but that's a non-issue in a Prii so it would be constant.
    Some phones and plugs can have an em leak at the charging port that can interfere with an aux connection (wife's old Pilot I had an aftermarket power/aux setup that did that).
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    If you have a USB port, put your music on a USB stick. We have a JBL audio with navigation in our 2011 with no problem.
  4. Dyjital
    Dyjital Member
    84
    Oregon
    2023 Prius
    XLE AWD-e
    Downside is some people such as myself run Apple Music, iPhones and our iTunes libraries from our phones. A USB stick won't play protected .AAC files, they also don't stream Pandora. The headunits are only so advanced when compared to the current generation of iPhone or Android phone.
  5. Christian Wattengård
    Trondheim
    Excel
    It's only BT. I don't have USB and that's not the point anyway. It supports streaming over BT so that should work "Use option X instead" is not a valid solution. I haven't carried individual files since many years ago. Spotify and podcasts FTW.
    And it's not any kind of whine, it's like I'm playing the music on a DJ-turntable and fiddling with the pitch-shift at the same time. Very annoying and very obvious on the kind of music I like to listen to in the car (synthy EDM).
  6. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I get the same thing, occasionally, with my 2010 via Bluetooth. I use an LG G4 with a microSD card to play my music files. When I used LG's player it did it really often. When I use Google Play Music, it's much less frequent.
    AzusaPrius likes this.
  7. Dyjital
    Dyjital Member
    84
    Oregon
    2023 Prius
    XLE AWD-e
    Good choice in music..
    I was having an issue with BT and distortion until I setup the device to normalize audio (on iPhone: Settings -> Music -> Sound Check (on)). When a track would increase in volume over the tracks normalized audio. --- if that makes sense???
    Have you tried that? What it's appearing to be is a mismatch between device output and processing on the HU's end.
    It's a start..
  8. wpointw
    wpointw New Member
    Quebec, Canada
    2020 Prius Prime
    Technology
    Oh no! Bad news because it does exactly the same thing on my brand new Prius Prime 2020 with my iPhone 8, using Apple Music. Congratulations for describing the problem, which is very hard to explain, but I am so disappointed to see there are no solutions here...
  9. AzusaPrius
    AzusaPrius Senior Member
    1,878
    823
    Dont turn the volume all the way up on your phone, maybe half way that should help. Use only the volume on the head unit and adjust the volume on the phone to remove the noise.
    Montgomery likes this.
