Strange Prius Behavior
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Brian Thomas, Mar 26, 2015.
  1. Brian Thomas
    Brian Thomas Junior Member
    The other day my Prius started doing this:
    (I apparently don't have enough posts to paste a clickable link)
    I usually keep my foot on the brake to start and stop the car. In the video you can see that when I press power, the car still seems to be on, but with flashing lights. This stops when the door is opened, but then reappear when the door is closed again. They usually eventually stop flashing after the door is open, but the passenger airbag light remains lit. I can only lock the car with the actual key as the fob doesn't work when this happens. When I press the power lock on the inside of the car, the car immediately unlocks all the doors again.
    Anyone have any clue what's happening here?
  2. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    How old is the 12v battery?
  3. Brian Thomas
    At least 3 years old.
    49,732
    you need to test it, to confirm or eliminate it as the potential cause.
  5. RRxing
    RRxing Senior Member
    2,520
    1,792
    NEPA
    I didn't notice the green light illuminated on the Power button when you pressed it. If your foot was on the brake and the 12V is okay, I'd suspect the brake switch behind the pedal. Without the green light, when you press the Power button the car goes into On or Accessory mode (I forget which one first), with no Ready light on the dash. Why the PRNDB lights were blinking, I don't know, maybe Gen II reacts differently.
  6. Brian Thomas
    I suspected it was the battery and so I replaced it. It seemed to work yesterday afternoon, but this morning the problem is back. I can drive the car just fine. It's just getting out and locking it is a pain since I have to use the key and all the lights in the dash.
  7. Brian Thomas
    I should add that when the car is locked manually with the key, the passenger airbag light remains lit, as well as the no key icon on the dash.
  8. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Which battery was that, the one in the FOB or the 12 V one in the car ??
  9. Brian Thomas
    The car's 12v battery was replaced.
  10. Easy Rider 2
    1,584
    257
    Ocala, FL
    I got nothing. Sorry.
  11. RRxing
    2,520
    1,792
    NEPA
    'Tis a puzzlement...
  12. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Just to make sure of the brake pedal switch, do the rear brake lights come on when you step on the brake pedal? It's a head scratcher...
  13. Patrick Wong
    18,200
    6,479
    This means that at least some of the car's electronics remain on, which will lead to discharging the 12V battery. You need to have your car taken to your local Toyota dealer to figure out why the power remains on. Most likely, the IG1 relay is stuck in the closed position.
    If you want to figure this out yourself, obtain the electrical wiring diagram at techinfo.toyota.com and find the relay which provides power to the SRS ECU. IG1 is that relay and is located at the relay/fuse box under the dashboard, driver's side.
    #13 Patrick Wong, Mar 28, 2015
  14. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Don’t let the 12V battery run empty. Your car is using it as Patrick Wong said above. Get the problem fixed before 12V gets empty. 12V battery getting empty will leave you stranded and it may ruin the 12v battery that isn’t cheap.
